LG RH1999H DVD Recorder/HDD Recorder Logo
A
Anonymous Posted on Jul 31, 2013
Can I record on LG HDD / DVD Recorder RH1988H
Can I record on LG HDD / DVD Recorder RH1988H using a HD TV
5 Related Answers
aewins
  • Posted on Apr 19, 2008
SOURCE: Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Anonymous
  • Posted on Oct 11, 2008
SOURCE: No sound from LG HDD DVD recorder
Same Problem here, have not done anything yet, but I am convinced that it is due to blown Capacitors in the Power Supply......
Anonymous
  • 3614 Answers
  • Posted on May 30, 2009
SOURCE: My LG, HDD/DVD recorder Model DBRH1979 cannot read
using a dvd/cd cleaner, clean the optical lens of the unit, it could be some dirt that make the player not to read every cd you inserted.
freekwb
  • 4 Answers
  • Posted on Jun 30, 2009
SOURCE: LG RH188S DVD/HDD recorder. 'Please wait'
Try reformatting the harddisk, worked for me!
Anonymous
  • 208 Answers
  • Posted on Mar 18, 2010
SOURCE: LG RH1757 (80 GB) DVD Recorder / HDD Recorder
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Hd recording
If the digital tuner can pick up the HD channels, then I don't see why it can't record them. However some TV channels have blocking on them to prevent recording. If it can't record a channel it will say so with a message, generally.
Backup hdd to external hd
DVD recorders are usually not the first selection for backup of data files. you may be better off with a 1 Tbyte external drive, which is suited for that purpose. Even though the DVD drive has the capacity, there are usually formatting issues with data files being burned to a DVD recorder.
I have a LG HDD DVD recorder which was given to me without any instructions. How do I plug it into the LG sound system and then the TV? I have 2 yellow white red leads and 1 red and white lead.
the red led i thingk is for recording,, light is power on,,, used rca audio output to connect to your lg.... or digital optic ouput... vidoe out to your tv video in
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
1helpful
HDD/DVD Model RH265 : worked perfectly for 14 months. Now will not allow deletion of data from HD and also will not allow recording to HD. Symbol circle with diagonal bar appears on screen . Still allows...
Sounds like the hard disk might be full. How many recordings have you got on the machine? You say it won't allow you to delete "data". Have you protected the recordings?
2helpful
How to record digital tv thru reocrder
You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
Can I copy vcr tapes with the LG RH 1999H dvd/hdd recorder?
I use the av2 input in the front of the recorder to copy my vcr tapes to the hard drive
10helpful
2answers
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
DBRH197
It only has a standard definition stb in it, the unit doesnt support high def. sorry, ****-face
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
