Dishwashers Logo
Posted on Mar 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool dishwasher chopper blade
My whirlpools dishwasher quiet partner 3's chopper blade screen keeps getting clogged. I think it is because the shaft the propels the chopper blade is not spinning the blade. The unit is about 8 yrs old and I am just thinking about replacing it. Can I remove the chopper blade and still use the dishwasher? I have a garbage disposal hooked up to the dishwasher don't know if that helps.
Ron Coons
Level 3:
President:
  • Master 2,651 Answers
  • Posted on Mar 31, 2009
Ron Coons
Master
Level 3:
President:
Answers
2651
Questions
Helped
1547582
Points
7824
You can replac the chopper as a seperate part, but will quickly clog, and destry ohter parts of the unit if removed. dont take this the wrong way but if you have a garbage disposer already rinse the dishes better to avaid further clogging of chopper
My Whirlpool Quiet Partner II will not drain at the end of the final cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Whirlpool gold quiet partner iii bearing noise
if its noisy when washing check chopper assembly. if its ok change the sump pump assembly
I have a Whirlpool Quiet Wash dishwasher. I don't
yes.. keep going deeper you will most likely find what is blocking the chopper from turning.
Sep 10, 2009 • Dishwashers
8helpful
Whirlpool quiet partner II top rack sprayer doesnt work
The top rack spray arm doesn't work because of low water pressure from the wash motor or it's clogged with debris.
If the top spray arm looks clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Apr 03, 2009 • Dishwashers
2helpful
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Whirlpool Gold dishwasher
Either:
  1. not enough water gets into the dishwasher. check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Whirlpool Quiet GU2300XTLS2
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
5answers
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
