2004 Honda VTX 1300 Logo
Posted on Mar 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Honda 1300c backfire through carb at wide open throttle. I have open up the exhust and rejetted the carb . the bike will run fine up to mid throttle or 65 mph but if you accellerate hard or go to wide open throttle it startes popping through the carb . i still have the factory intke ,air box and filter.the plugs are new also.
  • harryg6761 Mar 30, 2009
    i have one carb
tombones
Level 3:
  • Master 3,567 Answers
  • Posted on Mar 30, 2009
tombones
Master
Level 3:
Answers
3567
Questions
5
Helped
2100077
Points
15260
Try balancing ans syncronising the carbs.
BALANCE THE CARBS
Turn the throttle screw on the LEFT carb one half turn inward. Now start the engine and get it warmed up. With the engine running, remove the RIGHT spark plug wire. Adjust the idle speed on the left carb to the point where the engine just can't quite stay running and dies. Now put the loose spark plug wire back into place.
Now turn the throttle screw on the RIGHT carb one half turn inward. Restart and rev the engine. Next, remove the LEFT spark plug wire. Adjust the idle speed on the right carb to the point where the engine just can't quite stay running and dies. Now put the loose spark plug wire back into place.
Turn the idle screw on each carb EXACTLY ONE QUARTER turn outward and restart the engine. The engine will be probably be idling very fast. Adjust both the idle screws equally from this point to get to the desired idle speed.
SYNCHRONIZE THE CARBS
Remove the air filter and rubber fittings to allow you to see into the throat of both carbs. You may need a mirror to see inside. You need to be able to see the slides go up and down when you twist the throttle. Now turn the fitting where the cable goes into each carb such that there is just a bit of slack in the cable, 1/16" is plenty. Lock ONE of the cable adjusters down tight. All further adjustments will be made on the other carb.
With the motor turned off twist the throttle very slowly while looking at the slides. Both slides need to begin lifting at the exact same moment. If the slides don't raise at the exact same time then slowly twist the throttle until the locked adjuster slide just barely starts to move. Hold the throttle still and turn the adjuster on the other carb so that the slide on that carb just barely starts to move also. Now recheck the slide movement timing. Do this process until the slides on both carbs begin to raise at the EXACT same moment. Lock down the loose adjuster and re-check the slides.
Please rate this solution. Thanks!
  • tombones Mar 30, 2009
    I hate it when that happens. My lack of attention to detail.
    Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
    Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. If your carb has them, remove the two screws on the outside throat of the carb and spray into the screw holes as well.
    < < READ CLOSELY > >
    Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
    You may want to get the compression checked also. A valve may be going bad.
CB250 is backfiring
Backfire when throttle down can be;
1. dirty carbs that are running lean and need cleaning. Also the rubber grommets that hold the carbs can be leaking at the backside or even dry rotted.
2. no air filter
3. broken or open vacuum lines
4. an aftermarket exhaust that needs rejetting or an open exhaust system
I put a cometic headgasket on upside down in my sons 2005 cr85r
the rejeting of the bike is most likly the cause of the sputtering. Maybe the size of the jet doesnt suit the altitude check to see that the jet is not too big.
2001 Honda VT 1100 C2 Shadow Sabre Running Lean
I have a 2007 Honda Shadow Sabre VT1100 and I also put after market pipes on it from Vance and Hines. I also have to keep it choked when first starting and sometimes even hold the throttle a bit while it warms up. The bike has two carburetors and the best solution I have found by lots of asking around of mechanics and bike folk is to get it rejetted through Dyno Jet. It is meant for bikes with after market exhausts and much less back pressure from the lack of those stiffling baffles in the stock pipes. I have also noticed the power loss in the middle torque range and backfiring because of the bike running in a lean condition. The Dyno Jet website is a good place to find the correct set and corresponding part number, but then I suggest finding a cheap place online so you avoid retail price :) Hope this helps. Oh, and don't forget to buy two kits...we have two carburators in our bikes.
1helpful
2answers
Hi mt pit bike is spluttering under acceleration i have tryed to adjust air screw with slight difference but it is still not smooth under power. bike is fk1 125 dont know if valve clearence would be the...
Your bike may be jetted too lean. A common problem in these days of overzealous EPA regulations. You can tell if when you've cranked your throttle wide open and it splutters, if you back off on the throttle about 1/8 to 1/4 turn, it clears up. This is indicating that it is jetted too lean. When you close the throttle slightly, the fuel is being metered by the main jet and by backing off on the throttle a bit, you're cutting back on the air, thereby bringing the mixture closer to what the engine needs. Try rejetting the carb, Go up one or two sizes on the main jet, one step at the time.
Now, it could be too rich as well. If it splutters and blows black smoke out the exhaust, it either jetted too rich or the float level in the carb is set wrong.
Take care of the simple stuff first before rejetting the carb. Make sure your spark plugs are the correct ones and they are not fouled from overusage of the choke or enricher. If you allow the bike to "warm up" with the enricher on, plug fouling is common with this practice. I get the bike started and as soon as it will run without the enricher or choke on, I turn it off and keep the bike running with the throttle. Don't foul as many plugs that way.
1helpful
1995 honda xr 600r has been backfireing upon acceleration
Are you talking about "backfiring" out the exhaust or "spitting back" through the carb?
Backfiring through the exhaust under acceleration is rare. If he ignition is misfiring, unburned fuel and air mixture is exhausted into the exhaust system. The next time the plug fires, it ignites this mixure. In other words, your engine is "missing" and your ignition system needs attention.
If it's "spitting back" out of the carb, this is usually an indication of a lean mixture. If it's doing it at wide open throttle, you might need to go up one size one your main jet. If it's doing it under less than full throttle acceleration, raise your needle up one notch and try it again. You want to richen the mixture just a bit. Too much and the bike will get sluggish.
1helpful
Moified 2001 honda elite-s scooter overheats on long trips.
You shouldn't need to full throttle constantly. , or at least let up on it periodically so it can dump some heat
Bike backfires,dies,restarts runs fine
your carbs are dirty. and probably need to be balanced also... bring the bike bto a garage and have them cleaned by a profesional.... also after market pipes don't give your bike the proper back pressure .. that can mess up your carbs timing
Exhust
just make sure you rejet the carb all bikes come from the factory on the lean side to meet epa standards etc. if you dont rejet you'll actually lose some power and have nasty backfires as well take the time to put a jet kit in i personally recommend dynojet easy to install and comes with suggestions for your application
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
