A few weeks ago the convergence on my JVC 56" rear projection t.v. went out. I was able to realign it. A week later the green convergence on the top left hand corner started to curve downward and I was not able to align it. Now all three colors are not aligned but especially the green which is curving and I am not able to put them back. Is this expensive to fix or am I better off with a new t.v?
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move tGreen Convergence on a JVC 56" rear projection t.v - 2c07611.pngdirections your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Replace the ssb5068a & also the ssb5068a/r at the same time ,it's cheap insurance !
the "A" is for red &the a/r is for blue & green.Remembeer to check all resisters associated with them ,they will look burned out or well used .
Find a reputable tv guy in your area and they will be able to repair for you by replacing the convergence amps john
I have a JVC 56" rear projection t.v.. And the green convergence on the top left hand corner is curve downward and I'm was not able to align it. I can however adjust the red and the blue. How can I adjust the green? I'm vary greatfull for any help that you might be able to give me.
Thanks
I have the same porblem as the other 2 posters. The green color is "bowing" at the top of the screen. I can perform the fix I just need some direction. My tv is the JVC HV-53PRO. So I would need to purchase the service manaul and the schematics to aid my troubleshooting, correct?
Thanks for any help.
I the same problem with my 56 inch I"Art except it is the Blue color
Same issue
same problem but mine are all the colors
I have the same problem with green convergence bow in the top left corner which is not adjustable. Is it the convergence chip, cold soldier, or power supply? Any help would be appreciated.
