Put in a DVD and screen stays on "READ"....can not stop or eject DVD. Tried the reset button ....we get a series of "o" ....then a brief screen message with " H and than what looks like a backward 7 and then a 71" then the screen goes back to the "READ" message. Any suggestions on getting the DVD to reject?
SOURCE: DVD stuck in my Panasonic DMR-E30
To eject a disk if the unit won't operate (U99, etc.): With the unit
OFF, press and hold "Power", "Stop" and "Channel Up" for 5 seconds.
that's is your problem will be solved.
Goodluck,
Please don't forget to rate me as fixya..
SOURCE: Panasonic DMR-E75V DVD - How to use??
Can anyone help me find a manual for this item please?
SOURCE: DMR-EZ475V DVD Recorder
ive had this in the work shop befor the cogs can come lose inside the machine if your handy with a screw driver unplug from the mains and take the top of the machine and see if anything has come lose, 50% of the time you can fix this yourself if not you would have to contact panasonic and get them to send a engineer out to you.
SOURCE: Disc won't eject, stays in "RECOVER" mode
I have a panasonic DMR E-60 and had the same problem. What I did was remove 2 side screws and 3 rear screws and lifted top cover off. Then if you are facing the front of the unit to the right of cd unit there is a little nipple that locks the mechanism. Push that in, which would be to the left if your facing the front of the unit. Then press the eject button. Mind you it must be plugged in to power. Be careful not to touch any of the green boards or metal. Hope I was clear. I sent it to panasonic but they wanted 40. just to look at it and up to 140.00 to fix it.
SOURCE: On the Panasonic DMR-E75V DVD Player / VCR Combo;
You can enter the menu option on-screen - [FUNCTIONS] button, then, look for 'COPY' then select VHS as source DVD as destination.
Or you can download a .pdf copy of the manual ONLINE - it's free for this model.
http://service.us.panasonic.com/OPERMANPDF/DMRE75V.PDF - you can save this manual for future use.
