If you cannot find the automatic way of setting the hands, you can manually reset the analogue hands by pressing the mode button until you reach the "HS" mode and using the 2 or 4 o'clock buttons to adjust the hands.
This usually occurs when the battery is changed. There should be a process for synchronising the two times detailed in the manual.
To get a manual you go to "http://tissot.ch/" and on the black menu bar at the bottom of the page you will see "product support". Click on this and you will go to a page of instructions. Download yours and find the relevant method for putting your watch right.
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
advance the mode 6 times to H S mode and push left upper button till the digital time flashing, then push rigth doun or up buttons to advance, please read manuals
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
You can download the manual from the link below:
http://world.casio.com/wat/download/en/manual/?
You need to input the four digit code from the back of the watch.
Please update the question & let us know if the information given was useful to you - Good Luck!
