Computers & Internet Logo
A
Anonymous Posted on Jun 23, 2013
Download acer aspire one zg5 bios update - Computers & Internet
Level 3:
  • Computers & ... Master 19,187 Answers
  • Posted on Mar 08, 2019
Level 3:
Answers
19187
Questions
0
Helped
4344176
Points
82261
We need more information on your question.
5 Related Answers
Anonymous
  • Posted on Jan 13, 2009
SOURCE: Acer Aspire 1640Z BIOS problem
Dear all,
I also posted this one under "Notebook Bios Problems" which might notbe the correct place. Anyway here it is for you to see and maybe youcan learn from my experience.
Have done a VISTA upgrade with Acers upgrade DVD.
It recommended to upgrade the BIOS - after doing this notebook is dead.
(1 long and 2 short beeps).
If I want to flash a new BIOS with Crisis method which BIOS shouldI use i.e. how do I know if I need the AT or UMA version - how toverify this on the notebook (my version is 1642 ZWLMI)?
I would very much appreciate some help on this - thank you
LATEST NEW - it WORKS AGAIN:
I was a little bit worried when I started icon_sad.gif but later I was all smiles icon_biggrin.gif icon_biggrin.gif
So a BIG thanks to everyone who posted possible solutions here in this forum:
1: I bought a NEC model UF0002 USB floppy Disk Drive Unit.
2: Downloaded the zip file from the ACER homepage with the BIOS
(chose the one that should be the correct version for VISTA:
It contains 2 WHP files: ZL9A3A24.WPH and ZL9I3A24.WPH as I
learned from NoClaim's post I chose the ZL9I3A24.WPH.
3: Downloaded the zip files with the Crisis recovery zip-file (See d0gi's
post: http://www.rechner.org/b1800.html ).
4: un-zipped the files
5: copies the file ZL9I3A24.WPH into the crisis directory - deleted the
BIOS.WHP that was allready there. And renamed ZL9I3A24.WPH
to BIOS.WHP.
6: ran the WINCRIS.EXE program (did an unbootable format of the floppy)
7: I now had a recovery floppy.
8: all steps above obviously done on my desktop PC.
9: removed battery from my ACER 1640Z laptop
10: unplugged powercable.
11: inserted the USB floppy in one of the USB ports on the laptop
12: pressed the <fn> and <esc> keys
13: plugged the powercord
14: Turned on the laptop
15: waited a bit - lights came on on the laptop (no beeps)
16: waited a little longer and the light on the floppy came on
17: waited still a bit longer until I could hear the floppy was working
and then I let go of the keys <fn> and <esc>
18: after a while there was no activity on the floppy any more and
shortly after the laptop shot down.
19: the laptop started up again on its own and IT WORKED
20: THE LAPTOP IS BACK AND THANKS TO ALL OF YOU I SAVED A LOT
Anonymous
  • 340 Answers
  • Posted on Dec 17, 2008
SOURCE: wireless driver for acer aspire one series zg5
Hi there and welcome to FixYa,
I find that there is drivers for Linux, Vista and XP, go to:
this page
and choose you OS and all the drivers you need including your wireless driver :-)
Regards
/Teis
Don’t forget to vote if this was what you needed.
Thank you
Anonymous
  • 18 Answers
  • Posted on May 04, 2009
SOURCE: Bios reset on a acer aspire 1640z
To reset the bios in a laptop you need to unplug the power supply and remove the battery. Once you do that press and hold the power button for 45 seconds then put the battery back on and plug it in and then try starting it. Everything in the bios will be reset to the factory.
Good Luck
Anonymous
  • Posted on May 13, 2009
SOURCE: acer aspire one model ZG5 does not boot
After a normal restart yesterday, my Aspire One booted into just a black screen. No POST, no BIOS, no hard drive light activity, just the power button LED on and the fan running fast. I was not very happy…
I went to the Acer Aspire One User Forum and started looking thru the Hardware section. I found this thread Dead aspire one and it looked like many others had a similar experience. After reading many stories of warranty repair or replacement, I was just about to dig up my receipts when I found this post: Re: Dead aspire one.
It seems that a lot of people had success reflashing the BIOS from a USB drive using tools provided by Acer. I don’t know if it’s officially supported by Acer or if it will void your warranty, but if the computer’s a paperweight now anyway, what the hell?
It’s very easy to do, but the steps are a bit unclear so here’s my attempt to make the whole thing painless. This worked for me, but it might not for you, so do this at your own risk.
You need:
A working USB thumbdrive you can erase. I used an old 64meg.
UNetbootin. Download from here: http://unetbootin.sourceforge.net/
The files to flash the BIOS. I used the most recent version from here: http://sites.google.com/site/maclesblogspotcom/
Download all the files to an easy to find location.
Steps to prepare the USB drive:
Format the USB drive using the FAT file system, not FAT32.
Start UNetbootin and choose FreeDOS as the distribution. Screenshot here.
Unzip the BIOS files and copy them to the USB drive
Make a copy of the BIOS file and rename it as ZG5IA32.FD (this appears to be very important - my reflash failed until I did the copy & rename)
Reflash the BIOS:
Make sure the AAO is turned off, the battery is attached and the power adaptor is plugged in.
Insert the USB drive
Press and hold FN + ESC and press the power button to turn it on. Release the Fn & ESC keys. The LED in the power button will flash.
Press the power button again once and wait. Mine took ~3 minutes, but I’d advise that you let it sit there for at least 5 minutes just in case your’s takes longer.
When the reflashing is done, the AAO will reboot and, hopefully, you’ll be back to normal.
If it doesn’t work, try reflashing again. The keypress sequence is a little tricky.
If the second try doesn’t work, then you’ll probably have to send it off for repair.
Good luck!!!
http://chromick.com/eric/aa1/aspire-one-black-screen-of-death/
Anonymous
  • Posted on Jun 07, 2009
SOURCE: black screen on acer aspire one series zg5
I had this same problem and fixed it thanks to http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
1helpful
Bios notebook Acer aspire one 1754f zg5
pleas file Bios notebook Acer aspire one 1754f zg5 send /ok?
3answers
How can i download the driver for acer aspire one zg5?thanks
Here is a great place to get all of your drivers for your lap top or any other for that matter this is where I go to get them. You will also need a free torrent software download program I use utorrent.com once you download the driver copy it to a USB stick or a DVD or CDROM Or a FLOPPY if you have one. Then insert the download file into the drive then go to the Devices folder find the devices that are not up to date. Right click the one you are looking to update click update then select have own disk or you will search yourself. Then point the search to the disk. It should pick up the drivers off the disk.
Click Here for Acer drivers download site. John
Acer aspire one (zg5) missing home page/icons.
I will look into it. What distribution of Linux are you using?
17helpful
3answers
Can't find the equivalent model numbers for Aspire One ZG5
From ACER FAQs:
The Aspire One systems labeled with the model ZG5 are actually an Aspire One AOA110 or an Aspire One AOA150. Any information will be listed under AOA110 and AOA150, rather than ZG5.
The supportmodel number is located on the bottom of the netbook on a white label above the serial number. Alternatively, the support model number will be located in the BIOS which can be entered by pressing the F2 key when turning the netbook on. Once in the BIOS it will be under the Information tab to the right of Product Name
4helpful
5answers
Acer aspire one model zg5 battery won't charge
I have exactly the same problem and am searching at the same time as you. I think you are wrong. I think the 150 is for the larger screen model. I think we need the 110.
I think it's this one that i found at acer-euro
ftp://ftp.work.acer-euro.com/netbook/aspire_one_110/bios/v.3309.zip
but I'm afraid to use it (which is not to say I know how). Somthing about putting it onto a USB drive and running scripts. At least that's what they do with this problem on a 150
7helpful
3answers
Black screen on acer aspire one series zg5
You should contact Acer. They know they have a display problen with the Acer Aspire One that can be fixed with a BIOS upgrade. We got our done. They sent us a USB thumb drive with the files and instructions on how to boot the thumb drive. After a couple of minutes the Acer restarted and all is fine.
Acer One zg5 - updates now wont boot up
Right after the BIOS or POST keep pressing F8 do you get the option to go into safe mode?
Help me find driver for my acer atom zg5...its xp Os
Hi and welcome to FixYa,
The driver for your Aspire Acer Atom zg5 (WinXp) can be downloaded here:
http://www.drivers-software-download.org/tag/acer-aspier-one-zg5-sound
regards
/Teis
--> dont forget to vote "FixYa" if this Fixed Your problem :-)
Grand Canyon Tech
Grand Canyon Tech
