Microsoft Office Outlook 2007: Windows Logo
Anonymous Posted on Jun 18, 2013
Microsoft Outlook not accepting password
My Outlook isn't allowing me to send or receive emails. It keeps on asking me Network Password, but when I enter my password (which I know is correct), it doesn't accept it. It also won't allow me to change my password.
Alexey Krenvalk
Level 2:
Sergeant:
Champion:
  • Microsoft Expert 419 Answers
  • Posted on Jul 30, 2013
Alexey Krenvalk
Microsoft Expert
Level 2:
Sergeant:
Champion:
Answers
419
Questions
0
Helped
309195
Points
517
You may try to restore outlook password by the use of pst password permissions outlook
This item http://www.outlookpassword.recoverytoolbox.com will be handy
4 Related Answers
abhvp
Abhay Pujari
  • 148 Answers
  • Posted on May 13, 2009
SOURCE: PROMPTS FOR PASSWORD REPEATEDLY-NOT RETAINED IN MEMORY
Have you installed all the updates from Microsoft? This problem keeps bugging sometimes when you are in hurry. I recommend update windows and install appropriate SPs from Microsoft. Then see the result.
argospete
Argospete
  • 1035 Answers
  • Posted on Nov 12, 2009
SOURCE: Microsoft Office Outlook 2007 Network Password Problem
Hi May.
Suggest you totally remove program, remembering to access program files and remove any file that might be left. hen reload/setup program.
Microsoft backup and update program, there's a lot!
Remember, backup important files first, preferably to a seperate HDD.
Anonymous
  • 5 Answers
  • Posted on Jan 06, 2010
SOURCE: can not send emails thru microsoft outlook
Assuming that you have entered the correct details for your email account and assuming it is a pop3 account the most likely thing is that you need to change the option in the more settings.
Select Tools / Account Settings.
Double click on the account you are having a problem with sending.
Clcik on More Settings
Select the Outgoing Server Tab and check the 'Log on to incoming mail server before sending mail.'
Select the Advanced Tab and set the 'Use the following type of encrypted connection' from None to Auto.
Click OK to save and retry send.
Anonymous
  • 3278 Answers
  • Posted on Nov 01, 2010
SOURCE: When I pull up Outlook
Hello.
For some reason, your configuration changed. Give this a try:
Go to Tools, Menu, then Email Accounts, Change/View Email Accounts,
Choose the Main Account you'd like to use.
In the Settings, Choose the Outgoing Server,
Check Box to authenticate SMTP authentication and Choose Use Same Settings As My Incoming Mail Server.
Hope this helps.
Why does my pc ask for a password if i want to send or receive an email.
Next time you put the password, make sure the box is checked that says "save password" or it will ask every time.
Changed my pasword yesterday and now i cant recieve or sned email. microsoft outlook says its a prrobblem with gmail account email address [email protected]
You would also need to enter the new password in Outlook, if you use that to send email. Here is a guide how to to that:
http://support.microsoft.com/kb/2697421
What version of Outlook are you using?
MOZILLA THUNDERBIRD
try to connect using microsoft outlook
2answers
Access outlook
what password computer or outlook
Reset an Outlook password to keep your program secure.
A Microsoft Outlook password keeps your email account secure from unwanted intrusion.
When you wish to reset your Outlook password, you must perform a multistep process to change your password first with your Internet Service Provider (ISP).
The password with your ISP mail server must be the same as the password you set in your Outlook program in order to send and receive emails.
Call your ISP and request a new password for your account.
Write down the password after you receive it to ensure you do not forget it.
Open your Outlook program, click the "Tools" tab and then select "Email accounts."
Select "View or change existing email accounts" and then press "Next."
Highlight the email account you wish to change (if you have more than one email account) and press "Change."
Enter the new password you just received from your ISP into the appropriate fields (entering it twice).
Place a check mark beside "remember password" if you want Outlook to remember your password each time you log in.
Click "Test Account Settings" to make sure your account works with the new password.
Press "Finish."
I forgot my Outlook password
http://office.microsoft.com/en-us/outlook-help/i-forgot-my-outlook-password-HA001113690.aspx
Microsoft Web Access won't send mail
If you are trying to send or receive an email in Microsoft Outlook and the password doesn't work, you can check a number of different things. Microsoft Outlook validates your email account with your email provider using various settings. Once it has validated your settings, it will send or receive email. It is not only useful to set up your email correctly but essential if you wish to use Microsoft Outlook.
Gather all of the email settings for your email account. These will be located on your email provider's website in an FAQ or support section. If in doubt contact your email provider to provide all of the settings. Look for any of the following terms: POP, SMTP, IMAP, SSL, SPA, server, and port number. Make a note of all of these. Determine when the problem exists. Check if the problem occurs when sending an email, receiving an email, or both. If the password error only happens with either sending or receiving, this narrows down the source of the problem. Click "Start," type "Outlook" and press "Enter" to open Microsoft Outlook. Click "File > Info > Account Settings." Select your email account and click "Change." Click the "Incoming mail server" field, if your error was when receiving email but not sending. Enter the full "incoming mail server" address as provided by your email provider. If your email is "IMAP" then change the "Account Type" to display "IMAP." Click "More Settings > Advanced." Make sure that the incoming server "Port" number is the same as your email provider stipulates. If your provider requires SSL, then click "This server requires an encrypted connection (SSL)." Click "OK." Click the "Outgoing mail server" field, if your error was when sending email. Enter the full outgoing server address. Click "More Settings > Advanced." Make sure the "Outgoing server" port is correctly set. If your email provider requires encryption, then select the correct type from the drop-down menu. Click "OK." Click the "password" field and make sure you have entered the correct password. If your mail provider requires "SPA," then click the "Require logon using Secure Password Authentication (SPA)" to enable it. Click "Next" and then "Finish." Your password should now work. Hope it helps.
2answers
Emails no longer come to Outlook but to internet provider (Cox)
Hi Martha,
When you logged in to webmail did it ask you to change your password? Does a box popup in Outlook asking you to change your password as soon as it opens?
If it does just enter your new password in the outlook window.
username: yourcoxusername
pass: your new webmail password
Enter password for account window. but it does not accept any password at all. this is in Mail on Macbook Air. In the setup / advanced the password is present. I can receive emails and sometimes, I repeat...
Sounds like your ISP is rejecting the password stored in mail. I used to get this a lot in windows with outlook express. The best solution I used to find was to remove all the mail settings and start from scratch setting them up again.
Outlook network password pop-up
You might look at this http://blogs.msdn.com/outlook/archive/2007/06/15/microsoft-office-outlook-connector-beta-released.aspx or look at this http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=819756&SiteID=17 it would be helpful to know what server you are trying to logon to AOL, Hotmail, etc... and I doubt it but are you on a network? if so specify
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
