These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
SOURCE: My TV won't turn on
2 (at least) main possible problems. 1) media box( place where
you connect ant, cable hdmi) which controls on/off is bad. If that is the case, there's nothing you can do. Protron doesn't sell
replacement parts for their tv's.The other(main) possibility
is that there is a problem in the power supply.Only a technician can answer that question for you.If it is a power supply problem, the tech may be able to rebuild it for you.
Camtek
SOURCE: can only turn tv on manually
what kind of universal remote did you use? I am having the same problem. I use my dvd/vcr remote but i have to get up to adjust the volume.
Remote not working...turned t v on with it and then it stopped working...where can I get replacement??
SOURCE: the samsung lcd tv remote control has stopped
Hello Jacqui,
When you press the number button or other buttons on the remote do they Feel Stuck? The reason I ask this is every remote I have ever Had always ends up getting something spilt on it.
If It feels like the button are sticking then you could always try cleaning it with a baby wipe or something similar Not a sopping wet cloth.
If the remote seems to be ok you can always check your remote is working. Firstly you will need a mobile phone that has a Camera on it.
With you mobile set it up so that your camera is on. Now what I would like you to do is Point your Samsung TV remote at it and press the buttons. Whilest you are looking at your remote through you phone you will notice that a light appears. This is due to the camera Phone not liking infra-red, ( you can not see this with the naked eye.) So try your power button and you will see what I mean. Now try the other buttons and you will see which buttons are not working and those that are.
If after doing this that certain buttons on the remote are not working full stop what I would suggest you do. Rather then buying another Samsung remote as they can be really expensive.
There is another way. A lot of your friends / family or maybe even yourself may have a Sky Remote lying about not doing anything.or you can buy them from Argos cheap enough.
Please follow the steps below and you will be able to tune your Sky remote To operate you TV
with the sky remote then.
Press TV
RED + SELECT ( hold this down until it flashes twice)
TV
0060
Try the volume if this works then press SELECT to save this to the remote. If not then press TV again then check the volume repeart this step until the volume works then Press SELECT to save the code to your remote.
Hope this helps you out and saves you some money buying an expensive replacement.
Thanks
Little Dish Fitter.
Only effect on TV
My sansui tv is automatically on and it shows only effect on tv message in right top side.how to clear that problem
my sansui led tv shows top of the right side only effect on tv message when i change menu or tv av button they are scrolling. plz fix the problem.
My Sansui lcd shows only effect on TV plzz solve the problem
