When I manually rotate the drum at a slow speed it sounds like marbles are rolling around outside of the washing machine drum. I don't think it is a bearing problem because when I spin the drum manually I do not feel or see any resistance. it actually rolls nicely. my wife thinks that my daughters beads were washed and somehow got into the outside of the drum. also when it is on spin cycle and is spinning at high speeds I do not hear the noise. My wife said that she saw beads inside the drum and removed whatever she had access too. my question to you is there an easy way of accessing the outside of the drum without taking the machine apart. Any insight would be appreciated. Thanks
SOURCE: Clunking during spin
I had the same problem.It turned out that the pump was clogged with coins and the pump was working way to hard to suck the water out with all those coins plugging up the pump causing the clunking sound and vibration during the spin cycles
SOURCE: Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
SOURCE: during spin cycle started making
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
SOURCE: Frigidaire front load washer model GLTF1670ASO
Check the shocks on the bottom of the drum. I had the same problem and had to replace the shocks because they were broken in half.
i dont know why this listed the machine as a frigidare. it is a whirlpool duet wfw9400sw00
