This issue caused due to a start up item from spysweeper
you can remove that entry from registry.
Start - run - type regedit
it will open up registry editior go to the below location and remove the entry and restart the computer it should fix the problem
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
You probably read web pages written in a language that displays Right To Left
(hence rtl100) There are several reasons why that file might corrupt, an
add-on of some kind being the main suspect. Go to start/run, and type:
iexplore -extoff
to see it that stops the error.
If not, try refreshing all system files with :
sfc /scannow
hope i was helpfull
good luck
