Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
Posted on Mar 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yamaha outboard motor manual
Hello, we have recently received a secondhand 8HP Yamaha short shaft outboard motor to use on our new dinghy, however, the water pump and fuel line need replacing. Can you please advise where I can obtain a manual for this motor? Thank you.
  • 2 more comments
  • nataliewainm Mar 20, 2009
    Thanks so much!
  • Anonymous Mar 22, 2014
    98 Yamaha v 225 cuts out and runs rough at midrange speed only all fuel pumps and filters replaced injectors cleaned what could it be
  • Anonymous Mar 24, 2014
    i bought a boat motor and the water system is nor cycling water like it should be and cant figure out what the problem is. would you please help me
    good afternoon; sorry my english: I need to know which is de serial right and the year of my outboard. it say Yamaha E 25 A ( 61 N S 001582 ) my imail : [email protected] thanks you !
Sid
Level 3:
  • Master 483 Answers
  • Posted on Mar 20, 2009
Sid
Master
Level 3:
Answers
483
Questions
Helped
191437
Points
1547
Anonymous
Level 2:
Champion:
  • Expert 202 Answers
  • Posted on Nov 11, 2011
Anonymous
Expert
Level 2:
Champion:
Answers
202
Questions
0
Helped
59261
Points
460
If you have not instaed a pump before dont atemp it
2helpful
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Does my 1979 johnson outboard charge the battery thru the powerpack?
Some models charged through a Magneto, but see if you can find the 1979 Year Manual. I have a 1979 engine myself in a 15Hp which is a Manual start(no battery) and I have a Sailhorse Johnson 8HP which has an electric port and is Manual start. I believe the 8HP would charge a battery as on a Sailboat the running lights needed power. The 8HP could power the lights directly.
Johnson offered options for electric start in lower HP units and options in charging systems to contain costs. You might get a better answer from someone by listing the HP of your motor. I was the original owner of the 15HP and remember the 9.9HP and others in the same Sales brochure. The Sales brochure may advertise more about the charging systems.
1helpful
2answers
8hp yamaha runs hot
In most outboards, it will flow through the prop itself (through the inner prop). There should be a stream of water coming from somewhere around the back end of the motor itself, called a telltale, which visually shows that the water pump inside the outboard is pumping water up around the motor. If you cannot see this, then there is obviously a problem with the water pump or pump impeller that needs to be corrected to prevent the outboard overheating.
Top Light Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
john h
Are you a Light Boating Expert? Answer questions, earn points and help others
