My Whirlpool duet washer is not draining. I am getting an F2 error message. What could be the problem?
If you hear the pump running and not draining, then take the toe panel off. Should be 3 1/4" screws on bottom. Remove the "coin catch". It looks like a BIG screw and it's white. Turn counterclockwise. There may be a sock, change ect...clogging it up. Dump it out and run machine. Have towel or bucket ready when removing coin catch.
Hello & Welcome to FixYa
F2 is a drain error in your washer, if
the unit is unable to drain then after 4 minutes it will display suds and then
F2. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
My whirlpool duet washer won't wash and won't drain?
