My 20016 self propel not propelling; making a grinding noise when i try to engage self-propel; put on a new drive belt and still not working; took off front wheels to grease and one side had the teeth inside of the wheel worn down; tried a new wheel and still grinding
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
How do u take off front gear box on toro self propell
Trying to replace the 20016 self propel cable. What bolts do I need to remove to take off the top plastic cover. Already took off the one under the lawnmower??
