I have recently imported Daihatsu Terios 2009 from Japan and it has VICS NHDN-W54G 76024 system installed. I know that this VICS model is designed to work in Japan along with supported technologies which we don’t have here but still I would like to change the language of this system from Japanese to English. This system has functions like DVD-MP3-FM-AM-SD-HDD. I would love to use this system if the language could be converted in English.
Any solution or suggestion on the above will be very helpful and will save me from buying a new system for car.
Thanks
I have recently imported TOYOTA Voxy 2006 from Japan and it has VICS NHDN-W54G 76024 system installed. I know that this VICS model is designed to work in Japan along with supported technologies which we don't have here but still I would like to change the language of this system from Japanese to English. This system has functions like DVD-MP3-FM-AM-SD-HDD. I would love to use this system if the language could be converted in English. pls give me a advaice my mail add [email protected]
SOURCE: HONDA INTERNAVI - English lang/software & operating instructions
Hi Peter, since there's no english language support in honda navi systems, my suggestion is to scrap the head unit and buy an aftermarket one. Kenwood or JVC 2-din units are compatible with Honda systems. If you have steering control, install SWI interface module (google: pac swi). If you have reverse camera, check that the player have CCD input. If the aftermarket unit have built-in GPS, make sure you load the map for your country. You can get a decent one for about USD400 (c/w CD / DVD / MP3 player and all those new stuffs).
SOURCE: 2008 Daihatsu Terios engine number location on the car
wow someone knows their stuff ,if not sure where numbers are i ask in our local annual vehicle inspection station ,dont you have one??
SOURCE: 98 DAIHATSU TERIOS AUTO, 1.3 4X4. REAR BRAKE
drums out of round,or if disc brakes discs warrped,affected by heat need maching at brake place
SOURCE: Cigarette lighter fuse for Daihatsu Terios. Where
the fuse you are looking for is lockated under the dash at the drivers side if you remove the small change hilder you will see it it a blue 15 amp on the right hand side of the box hope this helps
SOURCE: hi, i bought a toyota axio 2007 without an owners ...
Want to get a copy of the toyota axio (x) 2007 model.
