Error code 2454
SOURCE: Can't start up Konica Minolta Elite 5400 II
This problem usually occurs when the scanner software crashes, or the scanner is turned off in operation, or the computer is shut down before you quit the software, etc.
The K-M driver software gets corrupted.
I use mine with a Mac G3 Tower and OS-X v 10.4.9. What I do is search for all the Konica-Minolta components using OS-X spotlight and then delete them. After reinstalling the K-M driver software and restarting the mac, the scanner should work fine.
SOURCE: Error code on Konica Minolta C350
There is not a C0876 listed in the service manual. Perhaps it's a C0B76 - Finishing option Punch Unit Board Malfunction.
CAUSE: The shaft on which the gear rides is deformed. The punch unit cannot be driven from front to rear.
SOLUTION: Reform the shaft toward the punch unit rail. This will allow the drive gears to mesh properly so the punch unit can be mechanically driven from front to rear.
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: error 4 ... Konica Minolta Dimage Scan Dual IV
Use VueScan. A free trial is available so you can test it before you commit to buying it. Available for Windows and Mac.
http://www.hamrick.com
SOURCE: HOW DO YOU FIND Secondary codes in KONICA MINOLTA
Fatal error means that the mother board is broken.
