1) Faxing time takes too long even 1 page will take about more than 10 minutes to go through.
2) If faxing several number of pages always get a Result Jammed though all the pages went through.
Pls help me figure out the trouble. Thanks.
Medel Calayag
206-396-4883
SOURCE: paper jams
It sounds like you'll need new feed rollers. I could find some part #s for you if you felt confident replacing them yourself.
SOURCE: 7310 faxing problems
Try to reset the printer.
Take out the power cable without turning it off and then press # and 6 and while pressing # and 6 plug the power cabel and keep pressing the buttons.
The unit will turn on and then turn off...release the buttons and then press the pwer button and turn it on.
Try to fax now.
Also open the adf cover and clean the roller and seperator pad.
SOURCE: faxing
That is the same problem that I have. I think the settings for the fax have to be reset. I am calling canon to get help.
SOURCE: Faxing multiple pages
Faxing using the scanner glass, it would ONLY allow you to do it one at a time. You can Use the Automatic DOcument Feeder on the TOP part of your printer. load all those pages and try to do the faxing. That should work.
Please, let me know if the issue is resolve.
Thank you so much.
adonscott
