Cold water trickles out. Hot water doesn't come out at all. Cold won't stop coming out even when the cycle is stopped or the washer is turned off unless the water source is completely shut off.
If you turn off the water supply and switch the hot and cold hoses see if the problem the cold cycle is only trickling hot water. If the problem switches order a water inlet valve which is about $20.00. To replace the valve turn off the water and unplug the unit. Pull the unit out and remove the back panel. Disconnect the hoses from the valve and unplug the connecter. Replace the valve and plug in the connector reconnection all the hoses. Test the unit before closing it up.
Is that a difficult thing for a first timer to fix?
Take the hoses off the supply. Clean or replace the filter screens.
