Sewing Machines Logo
KatyBD Posted on Jan 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Upper thread getting caught on bobbin spool
When sewing the sewing machine seems to seize. Took off the free arm and opened the door to watch the bobbin, and saw that the upper thread is going around the post that holds the bobbin and sticking instead of pulling the bobbin thread up. Tried flipping the bobbin around, only helped temporarily. Ideas?
R.A. Ellis
Level 3:
  • Brother Master 12,731 Answers
  • Posted on Jan 06, 2018
R.A. Ellis
Brother Master
Level 3:
Answers
12731
Questions
Helped
2613537
Points
59176
Has your machine worked before? Check that it is the correct bobbin and bobbin case. Although,if it is the spindle that is sticking out through the bobbin case, that is the shuttle. Perhaps the shuttle is not seated correctly.
Otherwise, it would probably be good to take it for service.
5 Related Answers
Anonymous
  • 56 Answers
  • Posted on Nov 12, 2007
SOURCE: thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
A
Anonymous
  • Posted on Jan 24, 2007
SOURCE: bobbin jams
This is a common problem with all sewing machines. You must make sure that both needle and bobbin thread are behind the sewing foot and that there is at least 4inches of each thread before you begin stitching. Thread jams can also be caused by improper placement of bobbin in the casing. Place the bobbin in the case so the open side is facing you, the thread end should be on your right, then slide the thread into the opening leaving about 6 inches to pull through. It may look like it should be the other way, but there needs to be some tension. If these solutions do not help, you probably need to have your machine cleaned and adjusted.
Anonymous
  • Posted on Sep 22, 2008
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Anonymous
  • 4 Answers
  • Posted on Jan 27, 2009
SOURCE: Birdsnest and machine jams
I have a singer 457 (from 1964!!) that I inherited from my grandmother. It worked successfully many months, but then I developed a similar problem (birds nests, tangles in the bobbin assembly).
AFter messing with the tension, different spools of thread, and what not, I found that it was the BOBBIN that was the problem. Althought this bobbin is the same size and shape as others, there is something about it that knots up the inside of the machine EVERY time (as in within 15 stitches or less).
I tossed the thing and have been trouble free ever since.
I am now convinced that bobbins (particularily plastic ones) wear out.
Anonymous
  • Posted on Mar 31, 2009
SOURCE: thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Need help with singer quantum 9240, can't get bobbin to fill?
Serger Help
  1. Place spool of thread on spool pin. ...
  2. Pass thread end, from inside, through the small hole in the rim of the bobbin (illustration 2).
  3. Place bobbin onto the pin. ...
  4. Holding thread end, step on speed controller to run the machine until the desired amount of thread is wound. ...
  5. Trim thread ends from top of the bobbin.
https://www.singer.com/sewing-resources/winding-a-bobbin-alt
Machine will not pick up bobbin thread. ... - Your thread could be caught on something between the needle and your spool of thread if so, your thread will be too tight for the needle to pick up the bobbin thread. - Make sure that the upper thread is threaded properly. - Re-thread your machine, if necessary.
https://help.brother-usa.com/app/answers/detail/a_id/76369/~/machine-will-not-pick-up-bobbin-thread
Can someone please tell me how to fix my Brother Sq9050 sewing machine. It will not pick up bobbin thread. Just gets hung up & knotted up.
https://www.youtube.com/watch?v=1tgrAlQdX78
https://www.youtube.com/watch?v=LmEtmnkDIS8
Upper thread on embroidery machine jamming machine, and ending up with a bird's nest in the bobbin area.
Upper threading is wrong. Thread could be catching on the end of the spool. What machine are you using?
How to put together the bobbin case assembly
Replacing the bobbin case after changing the thread spool gets you back to sewing. The Singer Simple model is designed for the beginning sewer. Even with its simplistic design, often getting started takes a bit of time, concentration and practice. Without the bobbin casing properly in place, the machine will not sew. You can get the machine up and running again.
The little spool holds the thread inside the bobbin casing.
Turn off the power to the machine. Power is not needed for any part of the process. Turn the machine off and unplug for safety reasons.
Turn the hand crank on the machine to move the needle into the highest position. Move the presser foot the up position.
Open the hinged latch covering the front of the bobbin cover. This is the device that holds the spool in place.
Place the threaded spool inside the inner casing. Place in so the thread is running in a clockwise direction.
Slide the thread through the slot opening on the let bottom of the casing. The slot is next to the outer arm of the casing. Close the hinged latch.
Hold the casing so the outer arm is sticking straight up. The thread will be coming out to the left of the arm; lay it under the arm to the right.
Push the casing into the internal bobbin slot on the machine. It will lightly snap into place.
Replace the outer machine cover over the bobbin
Upper thread keeps breaking on Brother ULT 2001
the tread gets stuck on in the thread take up arm, there is a joint ware the arm is rived to gather, the thread get caught between arm and the rived sheet steel . . take little silicon gasket and fill in the joint so thr thread can't get stuck where its rived
2answers
Thread breaking, not even threaded in needle anymore, thread gets caught on spool sometimes
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
for the top & bobbin thread keep thread tails of 3 to 6 inches long pulled behind the needle before you start sewing
yes,sometimes the thread will get caught on the spool, you might think about getting a extra holder that sets behind the machine to hold those spool's that the thread get caught on, that's what I did.
Thread bunches up in the bobbin area and needle appears to be stuck and won't move. Almost like the thread wont come off the spool.
Check to see if the thread coming off the spool is tangling on the spool pin or getting caught in the crack on the spool top where the thread originally comes off spool. Make sure the spool pin is pushed all the way to the right to secure your thread and then back it off slightly so the thread pulls evenly off the spool. Whenever your bobbin thread gets bunched it is usually something is wrong with the threading of the UPPER thread and vice versa. Let me know if this solves your problem.
7helpful
6answers
The bottom thread gets all knotted up when I sew... everything locks up and there is a mess of thread on the underside of what I'm trying to sew. help?
The tension in the top thread is controlled by a dial, and the tension in the bottom thread is controlled by a small screw on a spring on the bobbin. The tensions are supposed to be exactly equal in order to make the stitch perfectly in the middle of the cloth. Uneven tension will pull the stitch up or down from there. You can tug on each thread to feel how much tension there is. Often the bottom will get too much tension by just inserting the bobbin upside down. Leave the bobbin door open, and watch the operation. The top thread is pulled down around the bobbin. See if it is getting caught on anything?
5helpful
Thread knotting around bobbin case
1helpful
4answers
Designer One "broken thread"
If the upper thread spool is spinning allowing slack to the inlet of the tension assy and the machine gives a broken thread indication shortly afterward, the pre-tension assy needs to be adjusted. If the machine has the original "snap in" tension assy that was in the first generation of Designer 1, have it replaced with the modern "lay in" tension assy. Slack at the spool should never cause a broken thread indication as long at the thread is in the pre-tension assy.
Sulky thread will work as well in a Designer 1 as any other embroidery thread as long as it is properly adjusted.
One thing that you can look for, when the machine is sewing, watch the thread as it passes out of the left hand side of the tension disks. It should exit the disks at the 9 o'clock position. If it starts to drift up to the 10 or 11 position and then you get a broken thread warning, the pre tension must be increased.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
