Don Macphail Posted on Apr 06, 2013
SPACELAB DF-200 INSTRUCTIONS
INSTRUCTIONS
My Lowrance 525C Fish Finder comes on to Lowrance screen but does nothing when I mash any of the buttons. Eventually turns off by itself.
Question edited for clarity.
Make sure you got the correct transducer Your model comes in single frequency and dual frequency. Make sure the connection on the back of the unit is good and you have no corroded or missing pins. Make sure the software is up to date.
Lowrance LMS-525C DF Fish Finder Parts
Product Description: Designed for salt water or downrigger tracking, this dual-frequency sonar/GPS chartplotter
provides additional 50 kHz readings, in addition to a high-res 480 x 480 display on a 5" screen
and many professional features.
* Dual-frequency 50/200 kHz
* Precision 12-parallel channel external GPS+WAAS receiver
* Lowrance radar compatible
* LowranceNET® networking (NMEA 2000® certification pending)
* High-speed ethernet connection links multiple Lowrance display units and modules to
operate independently on shared network data, including sonar
200 khz transducer PDRT-WBL Part #106-89
Shoot-thru-hull mount, 20 degree pod type with remote temperature (200 kHz). (20 ft cable) Dual Frequency Transducer HP-DFBL260 Part #106-82
Thru-hull-mount, dual frequency bronze housing, high-power multiple element (50 kHz 19 degree
& 200 kHz 6 degree).
HST-DFSBL Part #106-77
Transom-mount, dual frequency skimmer with built-in temperature sensor. (25 feet of cable)
https://www.google.com/search?q=lowrance+lms-525c+df+software+update
2005 suzuki df 200 rev limit light stays on , after system check and stays on while engine running ,wont let me run more than 2000 rpms. No other lights on can run all day a1200 rpms
what car, DF?
in what country, we are a USA forum and we dont have DFs here.
so i cant read our books and see what your lights mean.
in general i can see , a rev limiter would activate
if the ECU/PCM is in limphome mode,
and if you had scanned your pcm the biggest clue is before your eyes,
you forget to scan it.
you cant fix cars, (with engine issues) with no scan tool
those days are long long gone. sorry
I can but have a huge cache of tools. endless. near.
you dont.
that is why its best to get car serviced. a win /win there.
Replacing element in De Longhi DSC 90 DF FSD
You are in the wrong category. You should be in the Electric stove or stove appliance category.
Terry
2answers
**** Fang wiring diagram?
chinese manuals not easy to find. but its similar to asian bikes. go to library thers many shop books wiring is pretty basic
1helpful
No bottom structure and depth flashes
your system is not locking to bottom ( bottom lock) go into menu scroll down to functions click it see if bottom lock is high lighted if not turn it on by clicking on it if it is on ..you need a new transducer
Can i replace my 330c head unit with the 525c using the same wires antennae etc lowrance
Hope its not to late, before you replace (buy a new one) call Lowrance. I have a 525 and working through some problems and they advised me that they would replace my unit for $200 no questions asked. To answer your question not 100% positive but I did see a recent question where Lowrance lost his unit and sent him the 525 as a replacement and the connections were different. I believe my 525 has a 5 pin system with one notch. Does yours have a external gps module? The 525 does!
3helpful
Vivitar DF-283-CAN flash suddenly won't go off. I hear it power up and the ready and ettl lights go on but the ok light doesn't light up and the test button wont work either.I tried replacing the batteries...
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
k24674
ADMIN Andrew
ADMIN Andrew
