I put in all the data i needed in the stat, then i fixed the window i needed so i could see all the plot points and i clicked graph and i only see the plot points and not the line? Help!
SOURCE: Plotting Points
you can reset all variables, without losing all your programs. you can hit 2nd>Mem(plus symbol)>reset>All ram Then verify that you wish to do so... It should reset to a working condition... If it doesn't then you may need to lose your programs in order to get your calc to a working condition.
SOURCE: Graphing Problem -URGENT-
The problem is causedby an application called "Inequalz".
To solve the problem, go to the Apps menu and select Inequalz,
then select "quit Inequalz".
This should solve the problem.
Gr. Marijn
SOURCE: TI-84 Plus Linear Regression (ax+b) ERR:DIM MISMATCH
Some old configuration settings, or old variables are spoiling your fun. Clear the RAM and start again.
Hope it helps.
SOURCE: whenever i try the graph
You have to turn all statistical plots OFF before you draw function graphs. Press [2nd][Y=] to open the statistical plot configuration screen. Press [4:PlotsOFF] and then [ENTER]. When calculator answers DONE you are ready to draw function plots.
SOURCE: i want to graph a
You're trying to graph a function that does not involve stat plot features but the calculator probably thinks you are. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
