U-Line Refrigerator Ice Maker Logo
Anonymous Posted on Apr 01, 2013
LG LFX25976ST refrigerator water in door but no water to ice maker
We purchased the fridge at discount due to damage while shipping. Ice maker has never worked. I can push the test button and the ice maker will cycle through the functions but will not fill with water. I just recently replaced solenoid thinking that was the problem but it still won't fill with water. During ice maker test I can hear it kick on but there is still no water going to the ice maker. Water in the door works fine. Everything seems to be functioning like it is supposed to but still no water.
  • Anonymous Apr 01, 2013
    No sign of a shutoff valve. I actually don't think I have access to the water line that goes to the ice maker. On the back the hose goes into the filter and comes back out and into a different spot on the back. There is only one water line going into the door so somewhere inside the door it must go into 2 lines. I can't figure out how to get access to that. I don't believe it would be frozen as it has never had water run to it. According to the service manual I found there is a built-in heater to prevent freezing.
  • Anonymous Apr 07, 2013
    I finally figured it out. I tested the water line coming out of the filter and it worked from there. I scoured the repair manual and realized there was another water valve in the door. I checked the other valve thinking it was going to have to be replaced. Turns out that the connection had come loose to the ice maker but was still connected to the water. I'm just glad it is fixed and I didn't have to call a repairman over something so simple.
marlin siecinski
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 512 Answers
  • Posted on Nov 22, 2013
marlin siecinski
Expert
Level 2:
Prodigy:
Answers
512
Questions
Helped
160217
Points
715
Check for 120 V at valve when it is supposed to be filling
Condensation from in door ice maker
More likely that the defrost drain is blocked. Does it do it once every 24 hours and normally you find the water in the morning?
Ice maker does not make ice
Is the freezer freezing the contents good?
Ice maker stopped working in lg refrigerator lfx25976st/00
I just slide the ice tray to the left and down till it unhooks from the right hand side. Then unhook the wires from under the tray. To replace just repeat in reverse order. I have to take our ice tray out ever so often to clean it since we have well water.
There is a little square button up under the left hand side in the back. If you press that with a screwdriver or butter knife it will reset the ice tray and it return it to fill with water.
Lfx25976st
Could be an open circuit to the ice tray sensor. This is the wire under the ice tray. It is flexed during each cycle and can fatigue easily. I found this condition on a three year old unit. A simple solder repair and heat shrink tube corrected the problem.
LG LFX23961ST with error code ER IF
could be bad fan. sometimes the sensors on the them go bad
NOT MAKEING ICE CUBES
well 9 1/2 times out of ten it is the ice maker i recommend you shop for a new ice maker... whirlpoolpartssurplus.com can get you a real good discount and free shipping...call them
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
