I want to give my Pi2515 to my daughter and need to format hard drive, I have the "operating system - recovery dvd" which I assume has the operating system. Can I clear the H/D and then insert the disc in? Will the dvd drive work if H/D is formatted? But I really need to know how to format the H/D first. Any suggestions
SOURCE: reformating the hard drive
just simply use a ordinary XP cd installer and you will have an option to delete all partitions and reformat the HDD (not quickformat). But normally errors like what you got there is caused by Bad cd or cd drive.
Hope this helps.
SOURCE: Hard Drive Replacement T30
change your boot sequence in the bios to 1st: cd 2nd: DD etc.... i think it is trying to boot fron LAN
SOURCE: How do I re-format Acer 4200 TravelMate hard drive?
Windows Reinstallation Disk option:
Insert Windows Reinstallation disk into tray, Boot to CD/DVD-ROM by pressing F12 at initial boot screens, delete existing Windows partition, re-create partition, and then follow steps to reinstall Windows. This will lead you to an option for formatting hard drive. I recommend choosing the full format versus the quick, from this point you can let windows install, or just shut the computer down when the format finishes. You will have to watch the progress, though, if you don't want the install to commence.
Boot disk option:
For XP, 95, 98, or ME, follow the instructions at this MS article page. It will walk you through creating a boot disk that will allow you to format.
You will need a floppy disk or CD
SOURCE: I can not make my recovery disc.
if you have recovery disc in dvd, just insert the recovery disc in dvd room.then restart you pc hit f12 to boot from the cd..after before you contenuing the instalation well ask if delete all or format.. befor to contenui be sure that you make partition in your drive.. ther are option to make partition, then contenui the installation with the recovery disc original.. good luck
SOURCE: it shows-recovery error-102 & error-104
Hi
i had same issue. nothing worked until i saw a guy who fixed his by dropping it on floor?
i dropped my archos in the protective case from 2 feet off floor. the bloody thing when came back to life, 100% good. i think the hard drive was stuck and the fall fixed it!! it cannot hurt as yours is broken still i guess. hope it works for you to
