I changed the spark plugs and the fuel filter, it will run full throttle if slowly ramped up
SOURCE: 46 inch cub cadet mowing deck
Go to... http://www.partstree.com/parts/ Click on the Cub Cadet logo then enter your model number. All the diagrams are there.
SOURCE: I need a diagram for the deck belt on my Cub Cadet
go to partstree.com put in your make &model #.then clickdeck assembly.hope this helps
SOURCE: Cub Cadet zero turn:Engine starts and runs about 5
You may have a faulty voltage regualtor that is blowing fuse. Have you tried a fuse that is 5 more amps?
SOURCE: my 50in cub cadet zero turn is having problems
you'll need to check your belts, and idler pulleys, check the spring to to make sure none came off. If your tran,y is making any noise, take it to shop righto way. good luck
SOURCE: I have a 2004 Troy Built Poney 17.5 Briggs &
what color is the spark at your sparkplug? If it's red, it's weak,if it's blue it's hot, clean the magneto contacts with sandpaper and wd40 and clean the coil too, let me know how you did!
