Here it is from the horse's mouth (TI Knowledge base)
For the TI-83 Plus Family, TI-84 Plus Family:
Caution:
The resets described in these troubleshooting steps will cause a lossof
applications, programs and data. If at all possible please create backup
using TI Connect™ first.
- Try a new set of AAA batteries.
- Adjustthe contrast by pressing and releasing the [2nd]
key followed bypressing and releasing the up arrow; repeat as
necessary. To adjust orlighten the display, use the down arrow.
- Remove one of theAAA batteries. Press and hold the
[CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then
turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
- Removeone of the AAA batteries. Press and hold the
[DEL] key. While holding[DEL], reinsert the AAA battery and then turn
the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83 or TI 84 Plus family to reinstall the calculator operating system (see below.)
- Removeall of the batteries including the round lithium
battery for 5 minutes.After the 5 minute period, reinsert all of the
batteries and turn thecalculator on. Adjust the contrast if necessary.
Reinstalling the OS for the TI83/TI84 Plus family
How
do I correct the Error Waiting..
.Please Install Calculator SoftwareNow
message on my TI-83 Plus family or TI-84 Plus family calculator? If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message
Waiting...Please install calculator software now.The
most common cause of a transfer being interrupted is updating
theoperating system on a calculator with low batteries. Users will need
touse the TI Connectivity cable and the TI Connect software to send
theoperating system to the calculator. Make sure to have the
latestversion of TIConnect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
Ifthe
message "Error! Press any key to turn unit off. Then turn unit backon."
appears on the graphing calculator, quickly, remove one batteryfrom the
calculator and reinstall it while the transfer is taking place.
Hope it helps.
