Daikin RXYMQ36MVJU, VRV-S Air Cooled Six Zone Outdoor Inverter Heat Pump - 3 Logo
Posted on Mar 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
U3 code error - Daikin RXYMQ36MVJU, VRV-S Air Cooled Six Zone Outdoor Inverter Heat Pump - 3
Felizardo Erilla
Level 2:
  • Expert 241 Answers
  • Posted on Jan 23, 2019
Felizardo Erilla
Expert
Level 2:
Answers
241
Questions
0
Helped
312514
Points
619
Just press test button for 5sec. in the outdoor unit to do the test run. Wait until test run completed.
Daikin MEA
Level 1:
New Friend:
  • Contributor 1 Answer
Daikin MEA
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2230
Points
Daikin VRV Systems reduces your energy consumption by optimising seasonal performance with efficient indoor and outdoor units, innovative technologies, and smart energy management controls. If you are looking best VRV Systems with great durability and comfort. Each VRV unit is equipped with signature VRV configurator. There is a software solution that simplifies easy configuration and commissioning. Your installer spends less time configuring the outdoor units and it's easy to customise the settings to your building's needs.
Don A
Level 3:
  • Daikin Master 4,380 Answers
  • Posted on Jun 16, 2017
Don A
Daikin Master
Level 3:
Answers
4380
Questions
5
Helped
1319476
Points
25565
Xerox 5020 u3 code reset
como resetear o resolver el problema del codigo error u3 xerox wc5020
U3 error code
I believe U3 error on your model of dishwasher could also mean a couple of other things like either the drain hose has an obstruction (kink) or the inlet water pressure is not correct.
Hope this helps in finding out what could be the actual reason. T
o find the kink if any, pull the drawer out as much as possible and feel the hose. Might be better if you took the bottom drawer out from the casing and inspect the hose completely. As the problem is limited to upper drawer you do not have to worry about what is under the bottom drawer. Check the water pressure setting is same for both drawers. If so then that is not an issue as bottom drawer is working ok according to your description. See your manual for instruction on how to check the water supply pressure setting on your dishwasher.
U3 error code
Error code U3 could mean the drain pump could be blocked.
Remove the trays and the impeller arm. Empty the water with small container or towel. Open the filter plate and drain filter. Get the motor out and check the cavity for any rubbish. Also use a stiff thin wire to clean the passage between drain filter and motor cavity. The instructions for removing the filter plate and motor assembly are in the user guide.
Good luck
I have an error code of U3 in the top drawer . It will not complete any cycle.
Error code U3 could mean the drain pump is blocked.
Good luck
U3 error for my pioneer pd-f605 100 cd player
I don't have the service manual with me at the moment and I'm on the road. I'll look up the error code and update this somtime tomorrow.
Dan
Error code u3
CALL TECHNICIAN NEAR YOU B COZ SOME WIRING CONNECTION PROBLEM.
4helpful
2answers
U3 code
I have had this problem and went straight to one of the F&P engineers... U3 will display because the water did not drain from the previous stage in the cycle... Check the HP/LP settings first as this will give the impression the water did not drain if incorrectly set. Otherwise the pump may be damaged, blocked or the waste hose blocked. Check these next. I found a little sticker in the waste pipe.
Happy fixing.
Rich
Top Daikin Heating & Cooling Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Daikin Heating and Cooling Expert? Answer questions, earn points and help others
