The device may not produce sound when it is in the fast forward or fast reverse mode. Also, you cannot obviously expect sound when the device is in pause mode. This not a malfunction. However, if the issue is due to other issues the steps below might help to resolve it.
- Unplug all the connections from your Toshiba rdxv60kb hdd/vcr/DVD player. Reconnect the connections securely.
- Make sure the connecting cord is not damaged and the connections to the amplifier are secure and proper.
- The audio will be muted if the setup menu or the timer-programmer display is shown, or if the screen saver mode is active.
- Check the 'Audio Out' settings if the audio signal doesn't come through the Digital Audio Out (Coaxial) jack.
- To get a clear picture, try the tips given below.
- Connect your TV and the DVD using a different cable.
- Connect the cable to a different port on your TV.
- Test the DVD with another TV.
For Quick HP Printer support 1-866-293-9220
