Vizio L32 32 in. LCD HDTV Logo
Don Horne Posted on Mar 20, 2013
"not support" message on Vizio tv when trying to use HDMI with Xbox.
I bought a new HDMI cable and tested it and it worked. The new cable doesn't work on my tv though.
Thomas white
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Apr 24, 2019
Thomas white
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
127380
Points
31
A non supported device. You may want to use the RCA. Cable that is available on ebay. I had run into this before. It is the software that is in the TV. Your game is fine. Some of the older model Tv's didn't see or be able to understand some of the game software from your games console. But it should do just fine on the RCA input on your TV. Green is video. Use yellow if you don't have the gaming input on your TV. With this I do wish you the very best and happy gaming my friend. From a true gamer.
Kenny Hartwell
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
Kenny Hartwell
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
18099
Points
Can we talk about how it says “not support” and not “not supported” that bothers me more then thinking about the TV being broke.
I just turn my cable box off then back on and it resolves the issue for a while.
5 Related Answers
Jerimy_smith
Jerimy Smith
  • 10 Answers
  • Posted on Oct 10, 2009
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
Anonymous
  • 56 Answers
  • Posted on May 12, 2009
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
Anonymous
  • Posted on Oct 27, 2010
SOURCE: My Vizio (VA26LHDTV10T) Tv says
You get this issue because the TV does not support the resolution your xbox is displaying at. I had the same problem with my PC since I use the TV as a monitor. The TV will do a max resolution of 1360x768 so, you need to set your xbox to that resolution or the one closest to it as long as it is under that number.
Anonymous
  • Posted on Feb 08, 2011
SOURCE: Hi. I have a
I am having the same problem. . . did you get it fixed?
Anonymous
  • 114 Answers
  • Posted on Nov 28, 2010
SOURCE: Our 42" Vizio will not display/play sounds when
Hello
One board takes in the HDMI as well as the other signals. Sometimes part of the board breaks and that is what sounds like has happend in your case. This is a fairly common problem and most people tend to just live with it. Others sell thier tv and a few find the number of thier board to see if one is available on ebay or shopjimmy. If you are comfortable with electronics the board is not hard to replace.
Im sorry your HDMI broke....
I hope this helps
Xbox 360 shut down when i connect to the TV. I have tried three different TV's and bought new HDMI cable, but when I connect my Xbox 360 to the TV, the Xbox turn on for 5 seconds.
https://www.youtube.com/watch?v=2QDu_mk4hEY
Vizio Model E470VL, HDMI ports are not functioning properly.
on some TV's the Analog board is where the other cables plug into. I know on a Sanyo I am working it looks like the analog and main digital board are all the same. but they are just hooked together. I bought an analog board for less that $30 from Shop Jimmy.com. The prices might vary according to the make and model of TV. need to be careful and remove the back of the TV . and get the part # directly off the board. BE SURE TO UNPLUG from the wall outlet first. Nearly all the boards carry a charge even when unplugged so be careful.
When I plug a brand new HDMI cord into my Vizio VA26LHDTV10T it says
Have you used the input display ie usb freeveiw hdmi avi ect because your tv will have a input display ?
I recently bought an HDMI cable for my xbox 360 (the new type, i don't know if it has a name but its the one with the touch sensitive power button), and when I plug the cable into the xbox and the tv...
Sorry to hear about your trouble. You elimanted the cable as a potential problem so that is good. You are left with a couple of options that might be causing the problem.
-Bad HDMI port on the XBOX
-Bad HDMI port on the TV
-Incorrect TV settings
On the TV, you want to make sure you set it to the HDMI input when you are using HDMI, but I assume you already do this and most newer TV's will auto adjust to HDMI when the xbox is turned on. Always good to double check.
The easiest way to narrow the problem down further would be to test the hdmi connection with another TV. If the xbox works on another TV then you narrowed the problem down to the TV and will need to repair the TV either through warranty support, by yourself or via a TV repair man. If the xbox has the same trouble on a different TV then you know the problem is with the XBOX and you can contact Microsoft Xbox support for repairs.
Let me know if you have any questions.
Regards,
G33k
BRAND NEW 42in. vizio 1080 LCD HD 120HZ picture not clear
the tv models in store are usually have samples from blueray dvds. standard dvd players will look fuzzy because it only submits standard dvd picture quality. you can try an upvert dvd player. tho i cant promise picture quality. i have an xbox 360 that upverts the quality. if you get a bluray player i recommend hdmi wires. if you get upvert dvd player and it has an hd outlet red, blue, green wires it might work. i havent tried one myself. if you dont want to spend money on bluray dvds. i recommend an xbox console. it upverts dvds through hdmi or hd red, blue, green wires
Motorola DCT6412 III and Vizio VW32L HDMI
After troubleshooting over the weekend, this ended up being the HDMI ports on my Vizio TV. Going to have to take it and get them fixed.
Xbox 360 hdmi cable
Make sure both the xbox and tv are on and tv is on HDMI source. It won't recognize each other unless xbox is turned on and tv is set to the correct source.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
