SOURCE: Konica Minolta Bizhub 920
the copier recognised the paper,but when printing/copying the feeder doesn't pull the paper and on the machine it says paper misfead,open front cover.
SOURCE: Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
