2007 GMC Acadia SLE Logo
Posted on Feb 24, 2009
2008 gmc acadia low beam light bulb changing
How do you change the low beam light bulb on the 2008 gmc acadia
  • 19 more comments
  • Anonymous Mar 15, 2009
    Can my low beam head light be changed by the owner or does it have to be done by a service center.
  • lagirl1333 Apr 12, 2009
    I also am wondering about the low beam light on the acadia. I can get to the bulb and even have the replacement bulb but I can not seem to disconnect the old bulb is there a secret???
  • Anonymous May 07, 2009
    how do i remove the old low beam bulb?
  • Anonymous Mar 13, 2014
    where do I find battery in 2008 acadia
  • Anonymous Mar 14, 2014
    replacing an oxgen sensor on an 2008 acadia
  • Anonymous Mar 15, 2014
    2008 acadia stabiltrak off displaying
  • Anonymous Mar 16, 2014
    Trying to find the #6 cylinder on the 2009 GMC Acadia.
    How does traction control work on a 2011 GMC Acadia
  • Anonymous Mar 17, 2014
    location of alternator in GMC Acadia
    not working on driver side
  • Anonymous Mar 18, 2014
    have changed the purge valve and the vent solenoid, what else could it be?
  • Anonymous Mar 23, 2014
    Need details about how to change out and how to remove glove box
    tried changing bulbs, fuses, swapped relays
    Number three cylinder on 2009 GMC Acadia
  • Anonymous Mar 24, 2014
    High beam still lights, but low beam is burned out
    I sent the car to the dealership and they want to change the whole injections ?
    the rear liftgate on the 2008 Acadia will not open when you hit the button. It will make the sound but will not open
  • Anonymous Mar 26, 2014
    Changing bulbs low beam
  • Anonymous Mar 31, 2014
    where is battery located
    change fuel filter 2008 GMC acadia
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6035
Points
30
  • Anonymous Nov 06, 2011
    Have to go in from the wheel well done it pain in the ****
  • Anonymous Mar 02, 2012
    check with your dealer, theres a recall on low beam headlights and sockets melting.
1helpful
2answers
How to change running light
"You Tube" will have a video just for you. Punch in your information and I am sure there will be an answer there for you.
How do you replace the drivers side low beam headlight on the 2008 GMC Acadia?
{: ) REMOVE THE LEFT FRONT WHEELHOUSE LINER
The wheelhouse liner is sometimes called the mud guard or the splash shield, whatever.
You may remove the left front tire.
-Start removing all those push pins and #7mm screws. No need to remove the entire liner. You may loosen only the half portion, just enough clearance for your arms to reach inside and aim for the rear of the headlamp.
-Reach for the Headlamp Bulb Accessory Cover. Rotate the cover counterclockwise and remove.
-Release the bulb from the headlamp assembly (turn counterclockwise) Disconnect the electrical connector. Just remember the positioning of the bulb so you can swiftly reinstall a new bulb.
How do I find the right part for the low beam connector for an H11 Bulb for my 2008 Acadia? I also need directions on how to install it.
I work at a GM dealership. It may be the parts department being lazy, but as of last week, we still are unable to get the electrical connectors and have just been having to replace the entire headlamp assembly.
2answers
2008 gmc truck Low beams quit working. I have High beams and running lights only. whats possible fix?
Are the bulbs good?
If your low and high beams are on the same bulb, then the low beam elements have blown even though the high beam still works, you need two new bulbs.
1helpful
I have tried to change my headlights on my Acadia and the area to reach is to small for my hands is there any other way to change the lights without playing with the lamp alignment?
Hi, viewer. In my practice, I was able to change the high beam bulbs and signal bulbs by removing the forward portion of the front wheelhouse liner. Lots of patience though. The low beam bulbs and the park lamp bulbs is somewhat difficult to reach, may even require removal of the whole assembly especially if the lowbeam bulb connectors are burned.
8helpful
How to change your headlamp in a 2008 gmc acadia
Open the hood and look in the area behind the headlight itself. You will see the wires running in to the light through a collar. Turn the collar counter clockwise and remove the assembly. Remove the bulb and plug in the new bulb and reverse the process to replace.
1helpful
I have no low beams on my 2009 Acadia. Fuses are
could be two blown bulbs or the control switch
4helpful
How do you change low beam headlight on the driver side of 2008 acadia?
1)first open the hood
2) check on the back of the headlight there is a socket coming out.
3) remove this socket which is the one that holds the bulb inside
4) replace bulb and put it back
12helpful
How to change the headlight on gmc acadia 2007 (driver's seat)
the low beam bulb?? it's not that hard turn the wheels to gain access to the wheel well and loosen the inner fenderliner (plastic) to gain access to the back of the headlamp assy
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
