Question about Waring Wine Chiller - Black
Need manual for waring pro wine chiller model pc150
Thank you.
  • gcowden Apr 30, 2009
    I need the manuel for the single bottle Waring Pro Wine Chiller. also, its quit cooling.
Go To wamhomecenter.com pull up product, check product details, click on product then print
Posted on Jun 06, 2009
    New Friend:
Posted on Jan 08, 2014
SOURCE:
Can anyone direct me to an operating manual for the Brandt Wine Chiller?
Search Results
    Download brandt wine chiller manual - Google Docs
    https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesLooking for brandt wine chiller manual? Download brandt wine chiller manual.brandt wine chiller manual. User Manuals, Instructions and Guides.We have that ...
    brandt manual Refrigerators Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > brandt manual
    On my Brandt wine cooler at the top is an adjustment control for temperature. ... is amanual for this refrigerator LG top mount ice box service manual Maytag ...
    Free Refrigerator User Manuals ' ManualsOnline.com
Dec 14, 2015 | Refrigerators
Has anyone replaced a compressor relay on this chiller? Looks like it is not designed for replacement, but if it can be done with a generic relay I would like to know. Thanks.
The cost of one of those compressors is over $100. When you factor in tax and labor you're better off junking it. Its also possible you have a compressorless cooler called Peltier.
Jul 30, 2014 | Avanti WC1500DSS 30 Bottle Wine Chiller...
How to remove cover from waring pro wo50
A broken cork was stuck up inside my Waring Pro Wine Opener. Model WO50B. No amount of maneuvering could get it out. I removed the two small screws holding the silver part of the opener on. After that was off I could see two more screws and I removed those. The unit still would not come apart. I noticed that there were four oval shaped rubber plugs up on the black part of the unit. I pried the ovals out with a wooden skewer. That exposed the other four screws holding the long part of the unit together. Once I got those out, I gently pulled the two sides apart about an inch. I could have pulled it completely apart at that point (I think) but from there I was able to free the broken cork from the big internal cork screw. Everything screwed back together fine and the unit works again.
Nov 20, 2013 | Waring Pro WO50 Cordless Wine Opener
Kitchen selectives rechargeable wine chiller bc-10r 8 minute chill
For the KITCHEN SELECTIVES WINE CHILLER...A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, plug in and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps! 8d55b92a-9870-497d-a9c6-7cda8d40c58a.jpg 11a83201-002b-4f0c-b811-810f4cf0046e.jpg
Dec 16, 2011 | Refrigerators
I have a kitchen selective mod. #BC 10R I dont have the operational manual for this and cant seem to get it to work. I dont know if it is broken or if there is an operator error. Please help me out. We use...
Hello, couple things first. This is posted under a cm-202 coffee maker yet the BC-10r is a wine chiller. Yiou are looking for the instructions for the wine chiller correct? Also I am a service repair person that repairs refrigerators and coolers as well so if you can describe what the unit is doing when you turn the unit on or plug it in as well as if you can see any led lights lit on the unit as well I would be able to tell you what is also wrong with you unit also.Please provide full model numbers and any serial numbers as well on your unit. I await your reply
Thank you
Rick
Nov 24, 2011 | Kitchen Selectives CM-202 Coffee Maker
Thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Feb 01, 2009 | Waring Wine Chiller - Black
Waring Portable Ice Machine Schematics
I doubt you will find any schematics for this unit. It should be pretty straight forward anyway. I suspect that uses a solid state plate cooler, and basic schematics for them, and their control board, can probably be found n the internet.
Jan 23, 2009 | Waring Wine Chiller - Black
Waring Wine Chiller - Black Logo
1,104 people viewed this question
Top Waring Home Experts
Andrew Taylor
Andrew Taylor
Are you a Waring Home Expert? Answer questions, earn points and help others
