Posted on Feb 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No audio I can not get audio out of my surround system from abrand new lg 42pg20 television.
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Feb 20, 2009
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2175092
Points
14133
You will only get stereo sound from that TV matched with that Coby instead of full surround sound, without purchasing additional equipment.
That Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
The manual for the Coby mentions a "Digital Decoder Amplifier," which would work. You would connect a digital audio cable from the area marked "Coaxial" on the back of the Coby to a digital audio IN on the back of an external amplifier. You would connect the speakers to this amplifier, instead of directly to the back of the Coby. Then you would need a cable or satellite box with digital audio outs (fairly common nowadays) to another digital audio IN on the back of the amplifier. The cable or sat box you may have already, but you may need to purchase such a "Digital Decoder Amplifier" or other digital amplifier with appropriate speaker wires and 2 digital audio input slots (not to mention two digital audio cables). Fairly complex. Possibly expensive.
-Tha Mp3 Doctor
Lg 42PG20 possible to work on a 220 volts?
The correct answer is "it depends on the power supply board used in it".
If you click on the picture at
http://www.coppelltvrepair.com/p/716/lg-42pg20-ua-power-supply-board-repair-service
and look at the lower left corner of the board you will see
100v-240V
printed in the lower left corner.
That board used in 42PG20 will definitely work on 220V.
Your TV may have a different board inside though.
DO not assume...verify.
Hope this helps!
Orange bars flashing around the screen
This is a link for repairing the power supply board of a LG 42PG20, which also contains a link to an article on how to test the board's functionality, which is actually fairly simple:
1helpful
How do I connect my old Sony 5.1 surround system to my new LG Plasma set?
You should be able to run most of your systems trough it. I do belive that it has IR connections that either your TV or possibly the cable box has to export the audio to the Sony. Hope this helps
M
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
How do i switch my lg 42pg20-ua to digital audio outpu
you shouldn't need to switch anything, you do however need an audio reciever with a digital audio in jack, that's all connect the d.a.o. to the stereo in the right jack, and you should be good to go.
42PG20 42 in. HDTV Plasma TV: i have an lg plasma tv - 42pg20 when i turn o...
There are several known issues that can cause that.
The top candidate is the main board, the next is the Y-Main board.
Here's a link for repairing the power supply board of LG 42PG20, which also contains a link to how to test your own board to see if it is good or not:
Hope this helps!
I want to have tv go through surround sterio
you need a optical cable to play tvs sound in suround sound
but that depends on if your suround sound has a optical in
your tv does not have phono terminal for audio out
Connecting LG 42PG20 TV to Samsung HT-Z320 receiver
output on TV cable digital reciever to home theater digital reciever in via an optical cable.lower the volume on the TV cable digital reciever to get the most out of the surround sound system.
Audio Problems
Did you try to lower the Bass level from the Sound menu?
Audio sync issues between my stereo and my new LG 42PG20.
i have samsung home cinema and a lg 42lc2d.
the samsung has 6 speakers but all i can get to work 1 front speaker.
when i trythe speakers on test mode they all work with the test sound
could you please help me
best regards ron mcneill
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
