My Magic Chef beverage cooler, MCBC580DBT, only cools when I bang on the side. Any ideas on wht the problem could be?
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
SOURCE: where can I find magic chef wine cooler compressor for MCWC52B
My Name is Mike. I have the same unit. The compressor is not bad. Replace the start relay& overload on compressor.
SOURCE: The magic chef wine cooler was clicking now will not get cool .
its your ptc relay.its a very simple fix.to the left of the compressor is a plastic cover with 1 screw.take it off.youll see a small box on top with 1 wire going to it.wiggle it off.pulls straight out left of compressor.go to repairclinic.com..type in part #1206838.its about a $27.00 fix. mines been running fine since.hope this helps
SOURCE: Magic chef wine cooler (30 bottles) is not cooling any more
if its clicking every few minutes its the ptc relay.located to the left of the compressor behind shield with 1 screw.go to repairclinic.com...part# 1206838
SOURCE: I have a Magic Chef beverage cooler, MCBC580DBT,
same problem w mine and yes if you take the cover off the inside display you will be able to remove the board mine has a hole burnt in it.unplug harness w red blue and brown wires and jump and jump from brown to red unit will turn on you need a new board
