Code c-5102
SOURCE: error code c-5102 in Konica minolta c252
C5102: Main Motor’s failure to turn
Relevant Electrical Parts
Main Motor (M1) Mechanical Control Board (PWB-M)
DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Location (Electrical
Component)
Check the M1 connector for proper connection
and correct as necessary.
Check M1 for proper drive coupling and
Check the PWB-M connector for proper
connection and correct as necessary.
M1 operation check PWB-M CNDM1-5 (REM)
PWB-M CNDM1-8 (LOCK)
L-2
5 Change PWB-M — —
6 Change PU1 — —
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
SOURCE: i want the image of
Image of the bizhub c252
http://kmbs.konicaminolta.us/content/products/models/bizhubC252P.html
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: how do i set up a scan box on my konica
Konica has a free program called PageScope Box Operator. You can download it from Konica's Web Site or it comes on the disk you should have gotten when you got the machine. Install it and from there you can pull up your scanned documents and you can create boxes. Plus it keeps everyone from accessing the printers Web Utility.
