Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Anonymous Posted on Feb 20, 2013
I want to change the setting of my drum unit on a konica minolta C-360
I have a konica minolta colour machine and the drum unit is due for replacement, can i reset the drum unit to get more copies
Adorjani Laszlo
Level 3:
  • Konica Minolta Master 1,316 Answers
  • Posted on Feb 20, 2013
Adorjani Laszlo
Level 3:
Answers
1316
Questions
Helped
456923
Points
2563
Enter in the service mode by press following keys:
Utility - Meter count-Check details - Stop - 0 - 0- Stop - 0 - 1 - Stop -0 -C - setting IU life stop setting and select NO STOP.
  • 1 more comment
  • Anonymous Feb 25, 2013
    Thanks for the information, Will this effect anything else on the machine
  • Anonymous Feb 28, 2013
    just wanted to know that by doing this will my drum life still reduce or will it continue give me prints till failure, because i have already put developer powder in the drums to increase the life of the drum, but the counter still continues please advice
  • Adorjani Laszlo Feb 28, 2013
    If you selected NO STOP for IU unit life,the message Please change the iu unit will continue to appaire on display ,press OK and ignore.You must need change the IU unit after the copy quality damaged.Aprox,20-25000 copies.
5 Related Answers
Anonymous
  • 60 Answers
  • Posted on May 27, 2008
SOURCE: Konica Minolta C450 User Manual
http://kmbs.konicaminolta.us/content/products/models/bizhubC450.html?info=Manuals
Anonymous
  • 16 Answers
  • Posted on Jul 19, 2008
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Anonymous
  • 192 Answers
  • Posted on May 20, 2009
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
chip_reset
Konica Minolta Error Codes and Solutions
  • 210 Answers
  • Posted on Aug 23, 2009
SOURCE: error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Anonymous
  • Posted on Mar 29, 2010
SOURCE: Can I reset the drum counter for a Konica Minolta
The best way to reset the counter is to replace the fuse on the underside of the printer drum. That is not hard to do, but you have to be careful not to break the plastic tabs holding the original fuse in place.
3answers
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
1helpful
3answers
My bizhub c451 is still printing only cyan and black after we change toner catridge, what could be the problem please
The problem could be the laser that scans the image or the detectors that see the colors. It could also be a problem with the power supply or the main board. This is not going to be cheap. If you want to continue, you should download the service manual.
http://www.printcopy.info/?mod=docs&brand=Konica-Minolta&gID=15037
THE PRINTING IS TOO DARK
You may be able to "manually" change your colour balances settings through the printer settings on your computer. If the machine is stand alone or connected to a network, try getting the machine to recalibrate itself. If none of these have any significant effect - it will need to be seen by a service tech.
2answers
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
How do I change a Drum Cartridge in a Konica Minolta Fax 2900 / Fax 3900?
toner and drum are separate the toner attaches to the drum unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
After the change drum unit machine wich is konica menolta ld 6500 is not received data from computer for printing.
you need to set the dip switches in system 2 and also set the iu setting to no stop in enhanced security mode
Konica-7222
the sensor did not sense paper passing through fusing unit.
check sensor by the side door, paper exit unit or paper passage
clean sensor, change if broken
check sensor spring
1helpful
2answers
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
1helpful
2answers
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Paper feed and colour problems with Konica Minolta bizhub c250
any stripes are usually caused by imagining unit, first use the tool in front cover to clean laser glasses. inspect IU drums for stripes maybe youll need to change them. is the page coming out ok, but picture is printed crookedly ?
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
