Whenever i recieve a new text my phone will not vibrate or play my message tone the screen doesnt even light up only the notification light blinks. anyobdy know how to fix this?
help would be appreciated :) thanks
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
• Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
• Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
• Ringing type — Select how you want the ringing tone to alert.
• Ringing volume — Select the volume level of the ringing tone.
• Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
i have the same problem... the phone doesn't ring when i get a message..it doesn't even display an alert on the screen.. the settings are fine. the phone rings when i get a call.. and the display message also flashes when i get a missed call.. but when i receive a message, the only way i get to know is when th green light around the joystick blinks ..help help
