I have checked plug, cable and fuses but it will not switch on why?
SOURCE: help w/ panasonic burner
I own one and it is a pain to work. Put in the disc and vhs tape and hit the bottom right button, I believe it says DVD and above it says dubbing. Hold it for a few seconds and the screen will come up and the system will do the rest recording from your VHS tape to the disc. You MUST finalize the disc after you are finished if you want to watch it in another DVD players if not it will only work on the Panasonic. Hope this helps. If not here is the site for the owners matual http://www.panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=2&productCategoryID=54
SOURCE: Panasonic DMR-E75V DVD - How to use??
Can anyone help me find a manual for this item please?
SOURCE: panasonic dmr es30v
Without seeing the actual unit, I would guess that the power supply has failed. These unit have what are called "switch mode" supplies that rely on circuits that oscillate. If a capacitor goes bad, the unit won't oscillate properly, thus no power. These are difficult to track, but are not usually expensive to repair. I would suggest a trip to a service center for a detailed repair estimate. Report the results here.
Dan
SOURCE: my panasonic dmr-e55 wont power up at all. i had
I had the same problem with my DMR-E55 over the weekend. I looked at similar problems and solutions for the DMR-E85 on this website. If you open the case, look for two capacitors that may have a bulging top end and a yellow/gold substance leaking out. If you see that, you have the same failed capacitor problem. Usually both will have failed, but the problem may only be noticeable on one. Replace both the C1260 and the C1261 while you are doing the work. Use the next larger uF and V ratings with both wires coming out of the end of the capacitor. Note the +/- polarity on the existing and new capacitors. Look at other solutions for similar DVRs on this website and club.cdfreaks.com I will try to post my photos on a photo-sharing website tomorrow. I will post a link here after I upload them.
Testimonial: "great idea! but where do i get the capacitors?"
SOURCE: dmr e75v user manual please
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
Testimonial: "Superb ! Bought the machine without remote or manual, but now I have both. Cheers ! RTJ"
