Samsung DLP HL-P5663W 56" TV Logo
Posted on Feb 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
56" screen dlp Samsung
Put a we control threw screen need a screen samaung wants $900 can I get a cheaper one some place
Anonymous
Level 2:
  • Expert 298 Answers
  • Posted on Feb 12, 2009
Anonymous
Expert
Level 2:
Answers
298
Questions
Helped
304262
Points
615
You can find a new Samsung replacement Lenticular screen and fresnel screen for a model # HL-P5663W from a major Samsung distributor at the following links:
Samsung HL-P5663W Replacement Part Fresnel Screen
Samsung HL-P5663W Replacement Part Lenticular Screen
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
How to change lamp in samsung dlp 56
Check the following videos to find out how to replace the lamp (BP96-00826A) of DLP HL P5663W.
http://www.dataentryjobs.us/70091.html
Ajin
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
1helpful
My tv have vertcal lines wend I just tern on but wend heat up dosent do any more ?? Samsung HL-R5656W 56 in. HDTV DLP TV
You are probably seeing what looks like Jail Bars (Vertical Lines evenly spaced) on the screen. If so,then the DMD chip on the DMD board is bad and needs to be replaced
2helpful
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
1helpful
2answers
Samsung DLP, coclor turn green every so often, but its fine watching a DVD, USUALLY HAVE TO SHUT IT OFF TO RESET THE COCLOR.
i once had this problem and found it was due an internal fualt in the chip controling the on screen desplay for menu and setting up functions flooding the screen with green
2answers
I can't fix the TV, but Nintendo does have the wrist straps and controller sleeves for the Wii remotes.
Samsung DLP RL-P5056W 56" TV Problem
IT MAY BE SEVERAL THINGS TRY SOME OF THIS ONES ADJUST THE BACKGROUNG USUALLY BLACK LEVEL, MAYBE THE LAMPS ARE OLD AND FADING. TRY THIS TWO ITEMS.
2answers
Samsung DLP HL-R5056W 56" TV Problem
How old is this TV?
I think its time to replace Lamp.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
