I have a second hand mezzo wm3011 front loader washing machine with no instruction manual. I don't know how to adjust temperature and there are three comartments with different symbols for the laundry detergent dispenser. Does anyone know how to use this washing machine or know how I can quickly view or download a free instruction manual. Regards, Bec
SOURCE: How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
SOURCE: LAUNDRY DETERGENT
Greetings MOMMA2,
Typically it is recommended to use only HE (High Efficiency) in your front loading units. The difference between HE soaps and normal detergents is that they are low sudsing soaps. HE Machines need low sudsing detergents and if regular detergent is used, the excess suds could lead to washer problems. Unfortunately just using a smaller amount of regular detergent does not fix the issue. Only the use of HE detergent assures the proper performance of your unit.
Due to this, it is NOT recommended using Dreft in HE machines.
One recommendation out there is to look for 2x Ultra Tide HE Free, which is made without dyes or perfumes.
Thank you,
Dorothy
Go Ahead. Use Us.
SOURCE: Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
SOURCE: mezzo wm3011
I find pushing gently on the door (as if to close it) frees up the mechanism and allows opening.
SOURCE: which compartment does my detergent/fabric softener go in?
You can get all of Whirlpools user guides here:
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001/ifu/home
Generally the one one the left - is for pre-wash (if clothes really soiled), the middle one is for powder (if you use it) and the last one is for softener or bleach.
I just use liquitabs - which go directly into the drum, and fabric softender.
