The hose came unattached from the faucet pullout sprayer and is stuck inside the faucet. I cannot figure out how to get is out.
SOURCE: delta 470 sprayer hose....have old one out. New
i think the heavy wight it loos or its out of the house so check that out
SOURCE: Delta single handle pull-out sprayer loose from ba...
Pull out sprayer has a plastic nut to tighten under countertop. You should be able to reach underneath and hold the top while tighting the bottom.
It designed to be tighten by hand to avoid damaging.
SOURCE: Do I have to remove
Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
SOURCE: Need to take the hose assembly out of delta 470 faucet
you need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
SOURCE: I have a delta pull-out sprayer that has separated
You need to have a second person feed the hose back up so you can grab it and reconnect
I have the same problem and none of the answers below helped. I think feeding it in from the other side is the closest correct answer but the damn thing is really jammed.
I had this problem too. The key is having a way to guide the end of the hose out through the top end of the faucet while pushing the hose up from the bottom. I used a flexible "grabber" tool to grasp the top end of the hose. It was not strong enough to pull the hose out by itself, but it stayed attached enough to guide the hose through the faucet while I pushed up from the bottom.
Hex Hangers can be suspended from a pipe or mounted straightforwardly to a surface contingent upon the style required. Materials of Construction can be custom fitted in Hex Hangers so as to help incredibly hot or cold liquid. See morehttps://hexhanger.com/
