I've tried every type of disc that I have. None will load. The machine goes through the motions of loading then gives disc error.
SOURCE: Disc loading, playing and then freezing
sounds as though you may have a slider problem or something is blocking it. The slider is what holds the laser assy as it slides along it like a rail while the motor drives the slider by a gear shaft system or a belt system.. I've seen in the past the grease or lubercation on this slider can harden up and ive also seen something getting inside like paper or little army men who wanted to hide out and was assisted there by a wee one. although these are common, another problem is that the tracking curcuit could also have a fault like alighnment or defective part now that would also include the tracking or slider motor too. Good luck
SOURCE: SD-3109 DISC ERROR
Sometimes the motor that spins the disk will develop a dead spot where it will refuse to start up and spin, so my bet would be either the motor or the driver IC that powers it. Depending on your model number (it should have either a letter B,C,E or U after it) it may need the whole mechanism replaced. Also at around the 7th year, it has been my own experience that the laser pickup gets weaker and will either stop reading the discs all together or start skipping part way through, so a complete mechnism replacement is probably the way to go for this repair, unless you find that the replacement cost is under $150.
SOURCE: toshiba SD-K850 trouble
I contact Toshiba Service and they suggest to unplugg AC cord then wait for 3 minutes but this is not a real solution ("Bad" message). I already notice other Toshiba models have the same problems (SD-K750 & SD-3980), and they are replaced them because of component part failure. (my DVD is a SD-K850).
They also explain that if that process not work, I must call their
Service Dept. for more details, same phone # (1-800-631-3811).
Luck!
SOURCE: dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year
warranty. Do not open the unit or it will void your warranty (I know, I
do Toshiba warranty repairs on their recorders. If anything will make
be void a warranty, it's a consumer who opens the unit and pokes around
inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive.
Clean the lense with a q-tip with a little windex on it. Work the head
up and down gently. Reassemble and test. If problem presists, go buy a
new one.
