Check the circuit board to see if the little 1 amp car fuse is blown, if it is replace it, if not, check to make sure the furnace is on and the door switch is engaged. if that doesn't work call a proffesional to come diagnose the furnace.
The oven is telling you that the secondary switch is not working. Either the switch is broken or the door or switches are out of alignment. the switches cost about 4 dollars. Not an expensive repair by any means.
Hello & Welcome to FixYa If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions. Kevin
From the manual: The main oven and companion oven are equipped with heavy-duty, porcelain - coated racks which are designed to remain in the oven during the self-clean cycle.
So they have nothing to do with your problem. From what you describe it appears that as the thermostat button is turned it either simply powers down the oven because the command wire for the clean cycle is disconnected or it trips some kind of overheat safety that is functioning incorrectly. The oven will have to be extracted from its place, its back removed to access the thermostat button (and its wirings) and the control board which will have to be tested. This isn't the simplest of jobs so if you have never done something like this before then you will have to call a pro. The parts won't cost much (less than $100) but the labor will so shop for the most affordable one.
