When I turn the printer on, it cycles through its normal set up and then gives me a paper jam error. I have tried compressed air to clean out potential dust, removed all visible paper from the front and rear. I removed the rear cover and reinstalled it as well as checking inside the front cover where the ink cartridges are.
SOURCE: hp psc 1315 paper jam
. Switch off the
printer and disconnect the power supply. Allow any residual charge
inside the all-in-one printer to dissipate before putting your hands or
any metal tools inside the chassis.
2. Pin down the exact
location of the jam. The 3 hot spots for a jam are before a sheet
completely leaves the paper tray, anywhere between the feed tray and
print carriage or between the print carriage and output tray.
3. Take off the front
paper tray if the sheet jammed while still in the front area of the
printer. If here, you should be able to see most of the paper.
4. Pull the sheet with
both hands and steady pressure. Do not tug as you might rip the paper,
leaving a piece deeper inside the machine.
5. Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6. Use the carriage
access door to get at a jam further inside the printer. You may need to
remove the print carriage to get to the jam.
7. Replace all parts and
return any access panels to their closed and locked positions. Plug
your printer back in and flip the power switch.
SOURCE: HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
please let me know what is rail and carriage bushings ?
SOURCE: HP PSC 1410 All-In-One Ink Jet Printer cd installer
i lost my CD installer and i need to install my prionter
