Hp Printer Error 49 is a communications error message. They can be tough to overcome since a few criminals actually make 49 mistakes. Often, these errors may be very brief errors that clear up with a reset or more permanent errors that need hardware repair.
HP Printer Error 49 on HP LaserJet printers is a connection error code that normally occurs when printing some document. It could be difficult to solve the problems if you have a few technological skills. You are expected to make use of HP Support Assistance in order to obtain advice from another qualified individual. It is the service provider tool that provides users with complete clarity of the HP printer issue. No matter what error code you're facing or what error codes you're getting on the computer, you're both going to get the desired response.
If you want an instant & expert-written solution check below.
I've seen this exact error a few times on the 4101s & turned out to be a bad EIO hard drive.If you replace the drive, you'll most likely have to download the newest firmware & load it to get every feature back. You can try & initialize the drive first though: - Turn off printer - Press & hold [Start] button - Turn printer on, wait for all 3 LEDs to stay solid then release button - Press & release [Left] arrow button (should read "Initialize Disks" on display - Press & release [Select], then wait for printer to warm up Listen also to the drive & if you hear it clicking over & over then it's bad & will need replaced.
If the error can be reproduced, use the following sections of this document:
Product-specific documentsProduct specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html. Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
Clearing the error
Validating the firmware
Stack Trace Random error troubleshooting
Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate errorIf the error cannot be eliminated by a power-cycle, use the following sections of this document.
Clearing the error
Hardware
Feature-specific errorThe error has been narrowed down to a specific feature.
Software, Sending, Faxing, and environmental troubleshooting
Clearing the error
Clearing the error
Hardware
49.XXXX PRINTER ERROR To continue turn the printer off then on
Description
The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action
Press Cancel Job to clear the print job from the printer memory.
Turn the printer off and then on to clear the error message.
Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider.
49 error normally means that the information sent to the printer is corrupted clear the print que shut down printer and restart. If problem still there then shutdown the printer then remove one of the additional memory turn back on if still same problem repeat removal of the next memory replacing the one you have just removed and so on. After you have done this and you are still getting the problem then it is 99% certain that the printer system firmware is corrupted or the formatter control board is faulty.
