I just changed the batteries in the tail light but can't figure how to open the headlight to do the same
You have to keep the black rubber, triangular button depressed while you slide it opposite way of the LED lights.
(Just face the LED lights side to your body,depress black rubber button and slide down)
Hope this helps!.
The top part move back
does the front pull out. is their a release spot
Once you hold the black triangle button down, the front clear LED cover releases. Then you just slide the white top part with the word Schwinn on it against the bottom white part to reveal 3 AAA batteries.
The clear front only covers the 4 LED LIGHTS. That only releases so you can then get to the AAA batteries by sliding the 2 white plastic pieces apart.
Wow totally worked, thank you, I was stumped!
