Televison & Video Logo
terri gowin Posted on Feb 01, 2013
My viper car starter will only work if i am standing directly in front of my vehicle
Brock
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Feb 09, 2013
Brock
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
7964
Points
56
Either the battery is too weak or you dropped it and antennae is messed up, or a transistor in the electronics is fried. I fix the remotes if you search ebay 7752 remote battery service. contact me there and I will look at it. If I cannot fix it, no charge just shipping.
  • Brock Mar 28, 2014
    If you need a new battery. There is a cheaper battery replacement site viperremotebattery.com and a youtube video how to change it. http://www.youtube.com/watch?v=GGnG5iCX0...
Viper model 7856V problems Car wont start with the remote starter but doors open and close remotely
ThersTHERS ONE IMPORT ANT THING ABOUCAR STARTERS AND THEY ARE SENSITIVE AND VOUNERABLE TO VIBRATION ISSUES DUE TO EXOTIC FIRM SUSPENSION AND UNFORGIVING PAVEMENT, ONE KEY EASY TRICK IS CHECKING THE CONNECTORS (WIRING DIRECTLY ON STARTER) IF NO VISABLE LOOSE NESS -SPRAY SOME WD-40 OR OTHER GOOD QUAILITY INHIBITOR RIGHT ON CONNECTORS . JUST A GOOD QUICK COAT. NOT OVERLY DRENCHED. I WOULD SUSPECT RESPONSE RIGHT AWAY. GOOD-LUCK FRIEND.
Viper remote starter malfunction
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U get free manuals
How do you unplug or remove viper remote system
You just need to remove the two connected to the starter wire (ignition switch), and connect the car side of the two together. Then the ignition switch will control the starter again, without interferance.
1helpful
How do i get the lock and unlock on the screen to work on a viper 479v remoet
The two-way remote responds when in range. Also, the system that it is programmed to must be a two-way unit. If this remote was purchased and programmed to an alarm/remote starter, the alarm/remote starter must be capable of two-way communication.
Just bought a`used truck that came with a Viper RPN 479VPC remote. Is this just a car alarm or is this a remote start also? Any help? Little blue remote with car diagram on screen...has lock, unlock, aux,...
That remote can work with both a security system, and a combo unit security/starter.
Best bet is to take the vehicle and remote to your local Viper dealer and they can look the car over and tell you what was installed and help you learn how to use it.
2helpful
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
2answers
8helpful
Viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
VIPER 160XVL remote start stopped working
sounds like the unit has lost power. i can't tell you where the relay is located for that device but it may have failed.
Car won't stay running after using Viper 150ESP car starter
you may have hurt the alternator when jumping check that
Top Viper Televison & Video Experts
Paul Bade
john h
ADMIN Andrew
ADMIN Andrew
Are you a Viper Televison and Video Expert? Answer questions, earn points and help others
