SOURCE: machine is locked
to open your door make sure all the water is out of your drum if not get the outlet hose and place on the floor into a bucket if water comes out than your pump is either blocked/faulty
SOURCE: Classixx 6 1200 bosch washer...I've
You've put the child lock on! When powered key press the on/off button for 5 seconds. This will remove the key!
Instruction Manual can be found here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
SOURCE: Door to my washing machine is locked and I can not open it.
I have the same machine, the pump is behind the round door at the bottom of the machine. use a heavy paper clip puched into the little hole to unlock it andwith a rattle motion turn the door clockwise and it will pop off. the pump is right behind it. It's a big screw cap, you will get wet if the machine still has water in it. Use a wet vac if you have one to catch the water. there is also a white plastic door release handle hanging there just a little tug with the machine off and the door will open. good luck ,Chuck
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
SOURCE: My Hoover Optima OPH 714 D washing machine won't start
Hi, the lights are coming on, but the door lights keep flashing and then nothing happens
