KitchenAid KSB5 Professional Stainless Steel Work Top Blender Logo
A
Anonymous Posted on Jan 27, 2013
How to replace Blender Coupling on KitchenAid model ksb5bu3 SERIAL NO. WJ4476934
Ross Keen
Level 3:
  • KitchenAid Master 1,365 Answers
  • Posted on Oct 17, 2019
Ross Keen
KitchenAid Master
Level 3:
Answers
1365
Questions
0
Helped
583305
Points
2445
I'm not familiar with that model number but if it is rubber with fingers sticking up then a large flat screwdriver under it and lever it up, bending it a little from 2 different sides and you should then be able to unscrew it (left hand thread I think) with your fingers. Failing that put in extra effort and wreck it off, the threaded part is aluminum and not strong enough to cause any damage to the motor shaft.
If the coupling is internal splines in a hole ask me another question.
2 Related Answers
Anonymous
  • Posted on Nov 10, 2007
SOURCE: Kitchen Aid Blender Rubber Coupling replacement
Someone else suggested a link that explains exactly how to unthread the old coupling... and it works. It took me about 90 seconds to fix my blender. But in case that link is dead, here's a summary:
(1) Note that the coupling (the round part with teeth) is threaded to the blender motor in reverse to a standard threading. So it screws off just like a bottle top, but in a clockwise direction.
(2) place the blender base on a tabletop, facing you. You should probably unplug it.
(3) take a punch or a flathead screwdriver, and place it against one of the coupling teeth that is furtherest away from you.
(4) strike the back of the screwdriver with a small hammer or maillot. The result will spin coupling clockwise. It may take several tries, but the coupling will eventually spin clockwise faster than the motor, and it will begin to unthread.
(5) unscrew the old coupling, and screw the new coupling into place (counterclockwise). Note that the new coupling will tighten itself every time you use your blender, so no need to worry about tightening it too much.
(6) Make a smoothie to celebrate your success!
Anonymous
  • 145 Answers
  • Posted on Jul 07, 2009
SOURCE: I have a Kitchenaid blender
When the lights are flashing, this does indicate that an electronic part has failed. This blender is no longer manufactured, so finding replacement parts for it may not come easily. Repair centers are available. I would recommend calling Kitchenaid Customer Service to see what they can recommend for you.
Their toll-free number is 1-800-541-6390.
Kitchenaid ksb540ero coupling
Drill a hole in the rim flange at the top. Engage a screwdriver in the new hole and whack it with a heavy hammer. You are trying to spin the coupling in the same direction it turns when the motor runs. This solution ALWAYS works if you do it right.
Blender teeth shattered
Coupling teeth??? Replace coupling, if the teeth on the blade part of the coupling are also damaged then you will need to replace the blade assy as well as that coupling only comes with the blades.
How do you replace the coupling on the  KitchenAid 4KSB5 5-Speed Blender
Buy the new coupling from Kitchen Aid, the instructions are in the bag with the coupling.
My blender has started to get hot and the rubber blade turner is being sliced off on the base
This is a common problem. This usually happens when either A) too many ingredients are added to the jar or B) the blade spokes do not sit properly in the coupling (the rubber piece). The coupling can be replaced easily. There is a great video on Applianceinsider.com on how to take the coupling off as recommended by KitchenAid themselves. The part can be found at 1800parts.com if you call them their reps are extremely knowledgeable and will be able to help you find the part in seconds. Or if you have the model number you can locate it right on their site.
Beaters
KitchenAid Turbo Beaters - Stainless Steel
Model: KHM2B
$14.99
Features:
Replacement or Extra Set of Self-Cleaning Stainless
Steel Beaters Mix Cookie Dough Easily.
Turbobeaters fit only Hand Mixers manufactured since
September 1997.
If you have a model produced before 1997 please call
the KitchenAid Customer Satisfaction Center at
1-800-541-6390 with the model and serial number from
your hand mixer for further assistance.
I have a Kitchenaid blender model KSB5BU3 marked "Ultrapower" and "Electronic Control" on the side. Suddenly all the buttons started blinking together after we pressed the On button and then one of the...
1helpful
The coupling of my kitchen Aid blender is broke could tell me how to change it
Visit MENDINGSHED.COM.
On the left, click KITCHENAID. On the next page, click KITCHENAID BLENDER PARTS. On the next page, you will see a listing for a drive coupling. You want to choose on the left, which is retailing for $5.95.
You may order the part if you need it. If not, click onto the parts order page and scroll down. There will be a two-step instructional guide on how to properly replace the coupler.
24helpful
2answers
Broke the coupling to our blender #KSB50B3
If you have a Kitchenaid Blender (model KSB50B3 or similar) and the rubber teeth on the coupling (that spikey rubber thing on top of the base) broke off (see picture), here is how you can fix it yourself! The Task: The coupling is screwed onto a vertical shaft like a button mushroom. The shaft is round with two flat sides. You need to find an U-shaped thing [such as a wrench] to secure the shaft and loosen the coupling by turning it CLOCKWISE. What you need: 1. New coupling: Part number KA-9704230. Shouldn't be more than $6. I got mine at www.goodmans.net. Their shipping fee is very decent and the service is also good. 2. An U-shaped object: Some had success with household forks. That didn't work for me. Most successes came from the use of ignition wrenches. There's only about 1/4 of an inch between the coupling and the base, and these very thin wrenches can get in there. You will need size 5/16 or 9/32. I got mine at Sears. They come in a set and are not cheap!! The steps: 1. Rip the rubber cover off the coupling. There's a metal disc inside. 2. Secure the shaft with the wrench. 3. Grab the metal disc with a plier and quickly **** it CLOCKWISE. This is to overcome the inertia. 4. If not loosened repeat steps 2~3. 5. Screw new coupling on COUNTER-CLOCKWISE. Now you are ready to make that smoothe or margarita or what have you again! Disclaimer: Kids, don't do this at home. I am not responsible for any explicit or implicit damages caused by you repairing your blender. Read manufacture's warranty policy before proceeding. Call their service center if you don't feel comfortable performing the aforementioned repair.
70helpful
14answers
Top KitchenAid Blenders Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
