The ski fell off of my Gyropter RC helicopter and it didn't come with a replacement ski.
Replacement parts can be found on amazon, take a look: Amazon com Gyropter RC parts. I hope this was helpful. cheers
SOURCE: My gyropter will not shut off. The blades keep
definetly a short circuit some were in the copter itself
There pretty good about returning those items they can be a lot of fun good luck james
Testimonial: "Thank you. Will be returning it and hope they have some more left. It would be fun if everything works. Thanks again."
SOURCE: My parents bought a Propel
I solved this same problem by removing the canopy and realigning the helix shaft with the motor gear. The small screwdriver provided will work. Be careful of the front white LED light when pulling the canopy off.
SOURCE: the gyropter will not charge
Check the charger adaptor if it has any output power. If no power comes out replace the adaptor.
Check also the battery terminal, it might already corrode and needs clean up.
If all does not work, the battery in the helicopter is already malfunctioning.
hope that helps you out!
SOURCE: gyropter not lifting off after full charge
Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out.
Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
Hope that helps!
