Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
Posted on Jan 27, 2013
My TI-84 Silver Edition Graphing Calculator malfunctioning
My TI-84 Silver Edition Graphing Calculator was working just fine when the screen started flashing and it deleted all but 3 of my programs. The next day I noticed that it was spitting out bogus answers for trig functions, including negative numbers. Help?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Feb 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
16851
Points
16
See if your setting are on degree or radian settings.
5 Related Answers
Anonymous
  • Posted on Jan 04, 2008
SOURCE: graphing trig functions
Put the calculator in radian mode and it will graph trig functions just fine. If you don't know how to change it to radians, then go to mode and cursor over to select radians. I am assuming you know where the sine, cosine, tangent, etc. keys are.
  • 102366 Answers
  • Posted on May 26, 2010
SOURCE: Im trying to access the memory menu on my TI-84
Having received no response to my second query in over a month, I assume this is no longer a problem.
  • 102366 Answers
  • Posted on Sep 12, 2010
SOURCE: My for the TI 84 Plus Silver Edition screen
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If that doesn't work, remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries.
If that doesn't fix it, please append a comment to this post and we'll go on from there.
  • 102366 Answers
  • Posted on Dec 04, 2010
SOURCE: My TI-84 Plus Silver Edition
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Anonymous
  • 100 Answers
  • Posted on Jan 04, 2011
SOURCE: When I turn on my calculator, I can't type
Hi persaud sabr,
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me anybody could make the same mistake. and of course the calculator will never come on if the batteries aren't in correctly.
The process below should reset your calculator.
Please be prepared to re-install the calculator's OS if you run through this process.
Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds. Now, Pressing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. Is the screen showing any activity? If not continue the process.
  1. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
    reinsert the AAA battery and then turn the calculator on. The calculator should display the
    message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message. If calculator did not display the message try pressing and releasing the [2nd] key followed by pressing and releasing the up arrow for one second. goto step 2.
  2. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
    "Waiting...Please install calculator software now". Follow the instructions for the
    TI-83 family or TI-84 Plus family to reinstall the calculator operating system. If the calculator did not turn on connect the calculator to the computer and open Ti Connect. Next, open Device Explorer. Is the calculator asking to be installed? goto step 3.
  3. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
  4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
If the above process did not work. Try re-doing the procedure and, extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
How do I fix the light on a TI 84
Press then release the [2nd] key. Press and hold the UpArrow to increase contrast (makes screen darker), or the DownArrow to decrease it (makes the screen lighter/fainter).
I have three TI-84 PLUS Silver Edition graphing calculators that will not work. Can you help me?
Having gone over a month without a response to my query, I assume my suggested screen adjustment solved the problem.
3helpful
How do I reset a TI-84 SIlver Edition graphing calcultor when the screen is frozen and none of the keys are working?
Remove all four AAA batteries. Press and hold down the ON key for at least ten seconds. Replace the batteries and turn the calculator on.
2helpful
3answers
My daughter's math teacher cleared her ti-84 plus silver edition calculator for the algebra regents but never put the software back in. how do I get her graphing calculator back to the way it was...
My screen was frozen and I needed to do a manual reset. If you take out 1 battery from the back....hold the "del" key down and reinsert the battery while holding it down....it will reload the programming into the calc
Graphing trig functions
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
